Solution for lifts/flats
Originally Posted by 91Toyota4x4
The jack top has a rounded groove in it so that it cradeles the axle. So instead of making a flat spot on the axle (dumb) they made a cylindrical impression on the jack (smart).
Originally Posted by Freezer
Don't the 265/75/16 and 285/75/16 have the same rolling diameter?
air the big tires down enough and keep the other inflated and it might be close...
It doesn't matter if your spare is smaller. On road your diffs are open which allows the smaller tire to spin faster (many cars are factory equiped with smaller donut style spares). Off-road even with a locked diff it's not a problem. The smaller tire will be forced free as it can't keep up with the larger tires. This happens with or without a locker in 4WD when you turn even when all your tires are the same size. It's a normal part of off-roading.
#25
fully inflated: nope. apparently it can be stuffed under there fully deflated, but unless youve got onboard air or run with guys that do...its not a viable option.
#27
my spare is usually in my trunk when i go wheeling. havent had to fill the trunk on any trips yet...so ill have to figure something else out when that happens. around town, it stays in the garage. a custom rear bumper may be able to get more room under there...
#28
JookUpVandetti
09-30-2015 08:58 AM
theBAYsic
09-16-2015 05:21 AM
Rickstwowheels
09-10-2015 03:51 AM
Mike Maiato
08-28-2015 02:35 AM
