body lift blues
Old Apr 25, 2006 | 07:26 AM
japskidda's Avatar
body lift blues
i have an 85 toyota ext. cab with a 3" body lift, i just swapped cabs cause the cab mounts had pounded up through the floor. has this happened to anyone else? the reason i swapped cabs was because of the same problem. does anybody have a suggestion? thanks
Old Apr 25, 2006 | 07:45 AM
tc's Avatar
tc
Get a better body lift.
www.4crawler.com
Old Apr 25, 2006 | 07:49 AM
seaflea's Avatar
X2 on the 4crawler lift.
Old Apr 25, 2006 | 08:25 AM
4Crawler's Avatar
Two common causes of that problem:
1. Using lift blocks with too small a diameter, concentrating the forces on a smaller area of the floor:
Too small a block:
Lift block at least as large as the body mount bushing:
More info:
http://www.4crawler.com/4x4/ForSale/...andardUltimate
2. Water leaking around the windshield or cowl area causing the cab floor to rust out and punch through.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
upongame619
Aug 1, 2015 12:12 AM
Cabell
Jul 24, 2015 12:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
