loss - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-29-2009, 07:09 PM   #1 (permalink)
loss
This is my first toyota. I got a 91 4runner it is lifted 5" with 35" tires. Iy has a 4.3 Chevy in it with a turbo 350 trans. My question is it does not have steering stabilizers on it at all. When you go over a bumper it is all over the place. Would a stabilizer fix this problem. Also it has no sway bar on it. Is that normal?
my91Runner is offline
Old 10-29-2009, 07:10 PM   #2 (permalink)
Old 10-29-2009, 09:41 PM   #3 (permalink)
4rnr's Avatar
Pretty typical of a POS 5" IFS lift, especially if it has been driven around for....maybe a couple years, and has been wheeled.
__________________
poop
1988 stock 4runner, v6, 5spd, soft top.
1990 fj62 stock and mint!
1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Mcintosh/Dynaudio a/v system.
The build up...http://www.yotatech.com/showthread.php?t=74915
4rnr is offline
Old 10-30-2009, 12:03 PM   #4 (permalink)
So what to do to fix?
Old 10-30-2009, 12:09 PM   #5 (permalink)
4Crawler's Avatar
Well, you could start with checking for worn components; tie rod ends, idler arm, ball joints, etc. If that is all OK, try putting a steering stabilizer back on and some sway bars with extended end links to restore them to the stock orientation will probably be a good idea.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-30-2009, 12:10 PM   #6 (permalink)
muddpigg's Avatar
Trouble shoot the front end. Factory FSM will tell you how. so will the books, chilton/haynes.
__________________
http://www.youtube.com/watch?v=rqtr_RvR3sY
Balljoints for sale. Open to trades and offers. http://www.yotatech.com/f11/ball-joi.../#post51278784
muddpigg is offline
Old 10-30-2009, 12:11 PM   #7 (permalink)
Get a steering stabilizer (probably not the problem but will help), chack the Idler arm for play (bet this is a problem) ball joints and TRE's. Those are the things that always made my truck feel loose and worn out. Each time I replaced them it was good till the next wheeling trip then it was idler arm busing time again.
__________________
93 2dr 4runner "overland build"
www.overlandcanada.com
89 Supra Built 2jz swap,T67 DBB and a Vipec V88.
Wheelingnoob is offline
Old 11-01-2009, 09:55 PM   #8 (permalink)
muddpigg's Avatar
I've got upper and lower ball joints if you find yourself in the market. Was going to replace mine but found a heck of a deal on a solid axle and decided not to put them on.
x2 part number K9587 amd x2 K9482
I chose Moog cause they were greasible. May an offer. I'm going to put them back in the classifieds so pm if interested.
__________________
muddpigg is offline
Old 11-03-2009, 05:55 PM   #9 (permalink)
Had a friend look at it. It has week leaf springs in the front. When you turn the tires you can see them flex and twist. I just have to find a place to get stock height springs for the front.
Old 11-03-2009, 06:28 PM   #10 (permalink)
whokrz's Avatar
It sounds like your 4runner has a solid axle swap. You probably have 48 inch springs in the front. They are measured eye to eye. You could probably make your own spring pack by removing and adding leafs until you have it like you want. It is hard to say with out seeing pictures of your suspension.
Make sure the leaf springs bolts and the u-bolts are tight. You could also check the wheel and trunnion bearings to make sure they are not loose.
__________________
1990 4runner, 22re, R151, 4.7, 5.29s, E-locker front, Lock-Rite rear, 37" MTRs, 51" rears all around
Trail Reviews http://www.gentryoffroad.com
Toyota Factory Service Manuals http://ncttora.com/fsm/index.html
whokrz is offline
Old 11-03-2009, 06:35 PM   #11 (permalink)
I will take a picture in the morning. This is my first toyota so i have no clue on what is stock and what is not. So bare with me. Thank you all for your help.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
