dual cases getting hot. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-29-2009, 09:04 PM   #1 (permalink)
kinzer's Avatar
hey, put in a dual 4cyl transfer case set up in my truck. 2,28 23 spline in front case and 23 spline 4.70 in the rear case. when using the front case the shifter gets really hot. i figured this is normal because more gears are turning causing more friction, thus heat. but its getting really hot sometimes. does this happen to other dual casers? my fluid level is good too. and i installed the oil galleys and pump.
__________________
They call me the "Short Bus"
89 pickup SR5 3VZ-E 5 speed 4X4
5" HD trail gear sas | rock sliders | u bolt flip kit | 6" shackles | 38X12.50 TSL's | led rock lights | 5.29's
dual t-cases 2.28 and 4.70 | welded front and aussie locked rear | bud built flat belly skid
marlin crawler rear bumper | trail-gear front bumper | x-plod amp & kicker cvr 12
Flowmaster | K&N system | 125" wheel base | cb
http://www.youtube.com/watch?v=yQbF4ThlNEI
Quote:
Originally Posted by Matt16 View Post
but if you only got 3" to start with, 5" is huge...
kinzer is offline
Old 10-29-2009, 09:12 PM   #2 (permalink)
tc
tc's Avatar
Mine gets pretty hot - you can feel the heat coming through the open hole in the floor (one of these days I need to get a shift boot ...).
Are you using dino oil? The lower friction of a synthetic might help.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is online now
Old 10-29-2009, 09:20 PM   #3 (permalink)
4Crawler's Avatar
Yep, mine do that, too. With conventional oil and driving at high speed for a long time, the levers are almost too hot to touch. With Redline synthetic, it is probably 10-20F cooler, still hot but not so much you can't touch the shifters.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-29-2009, 09:25 PM   #4 (permalink)
kinzer's Avatar
it mostly gets hot when using the low in the first case and in higher gears. id rather resort from synthetic, iv had way too many problems with this thing leaking. first was the v6 adapter plate didnt seal and i had to drop it all and re seal it, then the drive flanges were leaking, then the rear output housing. i think iv pretty much got a hold of the leaks, for now.
__________________
kinzer is offline
Old 10-29-2009, 09:46 PM   #5 (permalink)
4rnr's Avatar
it likely has more to do with heat coming through the floor now that you have cut it up. I have a large custom center console and I cant even touch it in the summer.
__________________
poop
1988 stock 4runner, v6, 5spd, soft top.
1990 fj62 stock and mint!
1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Mcintosh/Dynaudio a/v system.
The build up...http://www.yotatech.com/showthread.php?t=74915
4rnr is offline
Old 10-29-2009, 10:04 PM   #6 (permalink)
kinzer's Avatar
actually no, the first case, the one getting hot, is in the stock location. and i have a boot covering the hole. which im pissed about because dr smash started making triple shifters again! after i cut the hole.
__________________
kinzer is offline
Old 10-29-2009, 10:16 PM   #7 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Mine get hot as hell. I need to cover the opening and put on some shift boots.
waskillywabbit is offline
Old 10-29-2009, 11:02 PM   #8 (permalink)
kinzer's Avatar
__________________
kinzer is offline
Old 10-30-2009, 01:19 AM   #9 (permalink)
ocdropzone's Avatar
Mine get hot too but you might wanna separate the two cases and make sure that none of the oil passages are blocked.
I think that I will give the synthetic a try. The ice in a cup melts pretty quick in mine...
nice clean job on your install by the way..
__________________
~Robb
'81 Trekker The B4Runner Build
TREKKER Forum
Mini FAQ/Misc Ideas Thread
**TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES
LINK TO ONLINE FACTORY SERVICE MANUALS
Drive a real 1st Gen
Wheel Responsibly, Don't Screw It Up for Others
ocdropzone is offline
Old 10-30-2009, 02:02 AM   #10 (permalink)
turboboost's Avatar
My single case even gets really hot when I use 4LO a lot on a long day of wheeling.
__________________
1990 Toyota 4Runner - SR5, 22RE, 5 speed, 35" Mud King XT, a bunch of mods.
1986 Mazda B2000 - 5 speed, carb'd 2.0, the winter beater.
1979 Datsun 280zx - 2 seater, 5 speed, stripped interior, etc.
1998 Nissan Altima - 5 speed, 1981 280zx turbo snowflake rims.
1985 Toyota Pickup - SR5, 22RE, 5 speed, Xtra cab, lifted 2", 35" boggers, etc - Sold
1983 Datsun 280zx - Turbo Intercooled L28ET - Crushed.
1985 Nissan 300zx - 5 speed, race prepped, etc - Crushed.
IFS Club #7
turboboost is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
