Add a Leaf/Shackles
Add a Leaf/Shackles
I'm looking for about 2 inches of lift for the rear of my truck to match ball joint spacers and a slight t-bar crank. The truck will spend a minimal amount of time with the bed loaded and it is my daily driver. So, what would you all suggest? Thanks.
The Rancho Soft-Ride-AAL (http://www.gorancho.com/) are very good, 2 pair of leaves, on long/thin, one shorter/thicker that you can mix-n-match as needed for the lift and ride quality you want. Then if needed, shackles can be made to pick up the rest of the lift:
http://www.4crawler.com/4x4/ForSale/...shtml#Shackles
I got some short AAL's from JC whitney. They have been in for about a week so far. They havent quite broken in yet, but the lift is about 2". They ride pretty stiff, but still flex fairly well.
JookUpVandetti
09-30-2015 08:58 AM
Cycles
09-29-2015 06:37 AM
ktm192k
09-24-2015 03:36 PM
