87 toyota question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-22-2009, 08:49 AM   #1 (permalink)
87 toyota question
First of all you guys rock, love this site don't always log on but follow a lot of the posts.
Here's my question just traded for a 87 22re 5speed 4x4 truck , The previous owner installed a 3 inch body lift oin the truck, Here's the problem if in lo lock and try to go in reverse the tranny shifter knocks the transfer case shifter out of lo, Is there a way to correct this problem? Has anyone had this problem before?
Thanks
buckcreek
buckcreek is offline
Old 10-22-2009, 09:07 AM   #2 (permalink)
I never had that problem but I just read this the other day....http://www.4crawler.com/4x4/ForSale/...wShifter.shtml......cool site with a lot of good ideas......actually I think that site was how I found this place......
TubedYota is offline
Old 10-22-2009, 09:10 AM   #3 (permalink)
ocdropzone's Avatar
extremely common with a BL.
and you are in 4 low, not lo lock.
Easiest thing to do IMO is to remove the shift boot, pop the Clip holding your TC lever in place. Pull the TC lever out, heat and bend it slightly one direction or the other to get it out of the way of your trans shifter. DO NOT attempt to bend it while the TC lever in still in, you are liable to screw up a shift fork or something.
could also be that the shifter is hitting the opening on the transmission tunnel
Roger's site (4crawler) is an awesome place to learn a ton of stuff...
__________________
~Robb
'81 Trekker The B4Runner Build
TREKKER Forum
Mini FAQ/Misc Ideas Thread
**TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES
LINK TO ONLINE FACTORY SERVICE MANUALS
Drive a real 1st Gen
Wheel Responsibly, Don't Screw It Up for Others
ocdropzone is online now
Old 10-22-2009, 09:55 AM   #4 (permalink)
4Crawler's Avatar
A whole bunch of options below to fix that problem:
- http://www.4crawler.com/4x4/ForSale/...l#ManualTranny
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-22-2009, 11:33 AM   #5 (permalink)
Thanks for such a fast reply, I will check this out.
Old 10-23-2009, 09:38 AM   #6 (permalink)
I am on a very tight budget and would like to go with a two stick setup for the transfer case does any one know of a write up on building one of these for my truck (homebuilt).
Old 10-23-2009, 10:25 AM   #7 (permalink)
4Crawler's Avatar
Lots of threads on the Pirate4x4 forums about this, some below:
- http://www.pirate4x4.com/forum/showt...ght=twin+stick
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-24-2009, 10:38 AM   #8 (permalink)
great info !
how difficult is the pin in the case to remove?
Old 10-24-2009, 10:48 AM   #9 (permalink)
4Crawler's Avatar
Intrinsically not that hard, but depends on how cooperative your case is:
- http://www.4x4wire.com/toyota/tech/twin_stick/
I pulled mine some years ago with the case out of the truck. I hard the biggest problem with suction holding the pin in place, finally got a little telescoping pencil magnet, ground it down to fit in the hole and gradually worked the pin out. I don't have twin sticks yet, but been running unpinned for years now with no problem. Hope to finish up my triple stick shifter (dual cases) one of these months.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Tags
87, fork, shift, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
