Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
1st gen lift is finished!! w/ pics
chevy 63" long springs in the back with mixed stock rear/stock front leaves in the front... no blocks, no longer shackles... time for new tires
![]() heres a pic of 14" travel shocks + mounting kelly |
| Sponsored Links |
#2 (permalink) |
what size tires are you going to fit under here? 33s? 44s? ![]()
__________________
SOLD??? Never 1990 Automatic V6 4WD SR5 4Runner Mods: Downey 1.5 HDs, Aisin Hubs, CD, CB with a 4' Firestik, Husky Liners, Maglite Mod, 2nd Gen Airbox Mod, K&N filter and a Smittybilt Brush Guard with 4 lights. Next: Rims? Shocks? Exhaust? PICS -Corey |
#3 (permalink) |
im thinking about soem brand spanking new 35" mt/r's
#5 (permalink) |
It looks like you need a u-bolt flip kit for the rear springs too.
#6 (permalink) |
yea i know i looked for one locally, right now i have the ubolts long enough so i can run a 1 inch block but im going to get a flip kit if i decide to run more than that.
kelly |
#7 (permalink) |
those shocks look way too long...
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!" |
#8 (permalink) |
they wont be whne i throw an inch block on there... i designed them to run with a block
kelly |
#9 (permalink) |
ok, now, it appears that your double shackle in the rear is resting on the framerail. may i ask why? and if it is, did you put any kind of bumpstop on it?
__________________
-Joe Z Chicago 4x4 My Webshots 1985 Toyota 4Runner, 3" Trail Gear rear/ All-Pro front springs, 42x14 IROK's, Allied Rockathons, spool rear/detroit front, 30 spline longs, Dual cases w/4.7, Marlin High steer, lots of other stuff.. 1997 Dodge 2500 4x4, 12valve CTD, not stock. |
#10 (permalink) |
Look awesome kelly!! Hope you're havin fun back in az.
__________________
Rob |
#11 (permalink) | |
Quote:
kelly |
#12 (permalink) |
bump stops
you dont need the bump stops on the double shackles, but it will quiet it down a lot when it folds back downafter being extented. I would suggest that you come up with some kind of bump stop to keep from bending the chevys where they will come in contact with the frame right behind the front mount.thats just my .02 since ive been there and done it.
__________________
Larry 86 4runner given to me by a member of this board. it was a stolen recovery. It's done! 85 shortbed frame chevy springs in rear , 44044's up front, 15" travel shocks, custom rear shock mounts, ford mounts up front ,3"body lift, 3"drivetrain lift. 36" tsl sx welded in the rear and easy locker up front cutsom bumpers and sliders |
#14 (permalink) | |
Quote:
This current setup should droop for days but when one side droops the other needs to stuff just as much. This will lead to nearly all the weight carried by the rear axle going to the stuff side shock mounts. ![]() I've got $2 on a shock mount being the first thing to break when you try to flex it. Any takers? Last edited by jx94148 : 07-07-2003 at 10:27 AM. |
#15 (permalink) | |
Quote:
__________________
#16 (permalink) |
yes, shanes thinking is exact since they are at 45" angel 2" is = 1".... i can always remount them if i have a problem, but when i get new tires and throw an inch, inch 1/2 block in i think i'll be ok
kelly |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3rd gen winch bumper finished w/ pics | MossyRocks | The Fab Shop | 10 | 04-29-2006 11:24 AM |
| Pics of 1st gen with new Pro Comp IFS lift | CappyKD | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 01-02-2005 10:51 AM |
| Finished our 1st-gen 4runner 22RE rebuild | SoCal4Running | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-24-2004 10:46 PM |
| lift finished w/ pics | guinness | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 08-11-2003 07:53 PM |
