Who makes reverse cut 5.29 gears?
i normaly like to use precision gears.. i don't believe that they make a set of reverse cut gears this low.
any recomendations on a good (quality) r&p brand that makes a set this low?
any links to current sales/info are welcome.
thnx in advance,
~roland
thnx in advance,
~roland
Rate The Gear Manufaturers From Top To Bottom
Originally Posted by Curran
Get in line. There has been a national backorder on 'em for months and there doesn't seem to be any coming down the pipe. Randy's and Yukon are two names that come to mind. I don't think that Precision makes them and I'd be hesitant buying them from a different source.
i knew about standard 5.29's from PG being on backorder since last year.. i didn't know there was also a shortage of reverse cut 5.29's.
what brands are good to go with in a pinch like this..?
5.29 Gear Grind
I'm building a 4RUNNER with an FZJ80, electric locking, High Pinion 3rd. I literally searched for weeks and have come up with nothin'
..anyone have an update on this gear shortage.. i want to finish this project asap.
Not sure on the availability, but here are some links:
http://www.marlincrawler.com/3rd_pickup.html
http://www.inchwormgear.com/store/pr...products_id=43
http://www.allprooffroad.com/index.p...ask=view&id=20
I had Marlin build my high pinion front a few years back. I did go with 4.88s though, using OEM gears.
Guys:
There is a set of reverse cut Yukon 5.29 for sale on E-Bay right now. The seller is JT's differentials Axles. He's made 527 transactions all positive. Item # is 8008207082and it closes Oct 18 th. at 6:56 Pacific. According to the description he has 5 sets of these.
Good Luck
Good Luck
Post Update:
that is exactly who i ended up getting my yukon gears from last week!!
i got a V6 set for the rear and a high pinion reverse cut set for the front. the deal was pretty good and he had them in stock (so he shipped them out quick). the only other place that had a better deal was www.ironpigoffroad.com ...unfortunatley he was out of the V6 r&p. i prefer true V6 pinion, to a shimmed 4cyl set up.
jt is definatley another good source for gears www.ringpinion.biz .
Johntom240
7
07-13-2015 12:18 AM
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
