needing a lift kit
toyota landcruiser assoc: http://www.tlca.org/
off the top of my head check out http://www.ironpigoffroad.com/
http://www.man-a-fre.com/
http://landcruiserspecialties.com/
http://www.arbusa.com/
http://www.sor.com/
forgot these guys: http://www.metaltech4x4.com/metaltechnew.html
you 101? I was in the 6th ID LRSD falling out of planes a long time ago
http://www.sor.com/
if you take off the fender flares and add a 4crawler.com 1" body lift. you can run 295/75/16 (34.8") you might rub a little on on a full stuff, but not much. i am running OME heavies, cause i bought the 80 with them on it. a lot of the guys are runnning http://frankies4x4.com/ 3" lift. it has a progressive spring rate which soaks of the little bumps a lot better then the OME's. it is a bit more money but worth it if you want a plush ride. several people have just purchased the springs from frankie and then cut off one loop and gone with some 5150 shocks and slee blue caster correction bushings. as the wabbit mentioned IH8mud.com is your source for cruiser info.
try these guys, supposedly comparable to OME
http://www.ironmansuspension.com/index.html
the US, Canadian vendor:
http://store.camel4x4.com/merchant2/
i ordered my Ome lift kit from cruiseroutfitters.com fair prices , quick delivery and the guys was very knowledgeable.
i got to say: i had a xtra heavy kit (3inch lift) and could not fit 35inch tires whyout some major rubbing. forget about going offroading with some fender mods.
i did soa to fit my 35s, now they look almost too small
1985, cruiser, fender, frankies, frankies4x4, frankies4x4com, ih8mud, kit, land, landcruiser, lift, metaltech4x4, pic, shackles, sor, toyota
