habanero's 1996 4Runner Build-Up Thread
Old Sep 16, 2013 | 10:50 AM
  #1461
rworegon's Avatar
Hi Hab....from across the pond in Germany. Vacay is going good other than the nasty headcold.
I'll get caught up on the thread when I return.
Old Sep 16, 2013 | 12:16 PM
  #1462
habanero's Avatar
Hey RW, hope you feel better, what a thing to deal with on vacation! Glad you're doing good despite a messed up head.
Old Sep 16, 2013 | 05:23 PM
  #1463
habanero's Avatar
Removing rear door panel:
Is a lot like removing the front one.
Panel:
Push in middle and it'll come out, there's two, one on either side, nearer the top of the panel. You see them with the middles popped out because I did that to put them back in:
Old Sep 16, 2013 | 05:27 PM
  #1464
habanero's Avatar
Unscrew the door handle bolt, move forwards and out. Leave it hang, once the panel is free twist the panel to get the handle through the hole:
The arm rest pops straight up, it's held in by two metal clips:
Under the arm rest is two screws. Unscrew them:
Old Sep 16, 2013 | 05:33 PM
  #1465
habanero's Avatar
Here is a picture of the 7 plastic clips you are popping the lower half of the door panel off of. Actually there's only 6 there, one stayed in the door. They're the red things. They make a special tool, I gently pried until they popped off. If any stay with the door get them out carefully and put them on the panel for when it's time to pop the panel back on:
Reach behind the panel and unplug the window switch. I took it off because I plugged it back in so it could be used with the door panel off while I awaited parts- there's a catch front and rear:
Twist the loose panel sideways to get the door latch through the panel and you should be left with this (except the door handle will be loose and the window switch not there because it'll still be in the panel:
Now I've gotta put the kid to bed and then the fun begins.
Old Sep 16, 2013 | 05:59 PM
  #1466
habanero's Avatar
Alright, we've got the door panel off. Bear with me, this next part is kind of lengthy.
Old Sep 16, 2013 | 06:08 PM
  #1467
habanero's Avatar
96 4Runner, lots of miles.
Door lock actuator repair and a how-too for the door handle while we're at it.
As you may remember, last week I pulled the non-functioning right rear door lock module. I had power to it and it sort of worked, but not enough to actuate the lock button. Out of that darned curiosity I went ahead and pried the case open carefully (it is sealed shut) and found to my surprise a hobby motor. After doing some research I found out that others have done this too and even provided part numbers, which I found here: http://forum.ih8mud.com/100-series-c...placement.html
so thanks a bazillion to the contributors to it as there was great information including part numbers!
One Ebay search later on part # FC 280PT-22125 and I bought 4 of these little buggers for 19.95 shipped. Make sure they have a collar, mine came from MOPS Electric.
EDIT 9/30/2017 :
The MOPS electric motors I installed are still working great at over 295,000 miles
octanejunkie over at T4R found an ebay listing for a single motor, also MOPS, http://www.ebay.com/itm/271583579344
and gtdan at T4R found a set on Amazon that list the motor as Mabuchi or Nichibo in manufacture and a replacement for those brands in the description, looks like single motor,
Amazon Amazon
So, here we go....
Old Sep 16, 2013 | 06:13 PM
  #1468
habanero's Avatar
Panelless door. Pull back the plastic where you'll need access to stuff like the module.
Flip the white keeper up and pull out the rod:
I used a screwdriver to pry up 17 year old plastic just enough to release the door lock and door handle rods:
Old Sep 16, 2013 | 06:17 PM
  #1469
habanero's Avatar
I was unable to remove the keepers for the white plastic track thingy without breaking them so zip ties are what I used when I put it all back together. There are two keepers where you see red zips:
Unplug the lock module:
And this is what you've got so far:
Old Sep 16, 2013 | 06:20 PM
  #1470
habanero's Avatar
Flip up the greenish keeper for the door lock:
The keepers are kind of neat. Flip up, pull out.
Old Sep 16, 2013 | 06:23 PM
  #1471
habanero's Avatar
T30 torx to unbolt the door latch:
Unbolt outside door latch w/10mm here:
And here:
Old Sep 16, 2013 | 06:27 PM
  #1472
habanero's Avatar
To get the outside handle off lift up:
to clear the tabs along the bottom:
And jigsaw puzzle it out of the hole. It does come out, without force. Really.:
Old Sep 16, 2013 | 06:29 PM
  #1473
habanero's Avatar
Now it's just hanging by the keeper. Lift the keeper up and push the rod out. I had to gently use a pair of pliers to get it out:
Here's the backside for those interested:
Old Sep 16, 2013 | 06:34 PM
  #1474
habanero's Avatar
Unscrew single screw on this side:
the plastic cover is held on by that single screw and this tab:
And also this tab:
Unscrew the two screws on the other side:
Old Sep 16, 2013 | 06:41 PM
  #1475
habanero's Avatar
Pay attention to the white piece that slides up and down and joins the lock module to the latch:
It goes on a certain way.
Old Sep 16, 2013 | 06:47 PM
  #1476
habanero's Avatar
So here's the lock module pried open once again.
To unplug the motor pull straight up. The screw drive slides right off and fits over the collar of the new motor. I used JB Weld to tack the module back together, so far so good. I thought about putting a couple of screws in instead, but it's pretty tight in there. That little plastic bit at the bottom is a vent, it just slides on the outside of the module.
EDIT: Ended up with JB Weld and a couple o' zip ties for insurance, been working great for a year now. EDIT: Almost 7 years now.
If it helps anyone (and I haven't confirmed this) these motors are supposedly in the mirror actuators too.
Old Sep 16, 2013 | 06:50 PM
  #1477
habanero's Avatar
When I get a chance I'll pull open the old motor, just to see what's what.
Edit: pics of the old motor
And this pic shows the shaft you need, kind of short with a collar:
Old Sep 21, 2013 | 06:32 PM
  #1478
habanero's Avatar
Fixed the left front door lock module today, more involved than the rear but still pretty easy. This time I used a small screw driver and hammer to get the module open, that was a little easier. I just had to make sure not to drive it in too far because I didn't want to damage the gears or screw drive.
Old Sep 23, 2013 | 06:43 AM
  #1479
JBurt's Avatar
You're becoming the queen of tearing small things apart to fix them. Good job! Seems like an easy fix.
Old Sep 23, 2013 | 07:12 AM
  #1480
habanero's Avatar
Good morning! You're right, easy and cheap. The fix, not me.
