Where to get bump stops?
Old Sep 30, 2004 | 08:03 AM
colsoncj's Avatar
I'm looking for factory height or shorter front and rear bump stops for the suspension. I need the front four round ones and the rear stop that sits on the top of the leaf springs held on by the u-bolts. Anyone know of any vender that carries them?
Thanks!
Old Sep 30, 2004 | 08:06 AM
h7009's Avatar
Bump stops
Hey there, you can get them from PEP Boys, sometimes on the self otherwise JEGS has them mail order, I just bought the 4 front ones. about $18, Good luck
Old Sep 30, 2004 | 08:12 AM
evilcow's Avatar
I have seen the low profile front bumpstops at a local parts store once. I have also seen them at 4wheel parts. They are made bt energy suspension. Haven't seen the rear ones though. If you need stock try the boneyard.
http://www.4wheelparts.com/4wp/produ...E&expand=sub2#
Old Sep 30, 2004 | 09:58 AM
colsoncj's Avatar
Does anyone know the energy suspension part numbers?
Old Sep 30, 2004 | 10:38 AM
mt_goat's Avatar
I'm just using the Energy Suspension universal bumpstops. You can adjust the height by cutting them down. Here is a pic: http://community.webshots.com/photo/...67530768idjeda
Old Sep 30, 2004 | 10:42 AM
evilcow's Avatar
9102 is the low profile bumpstops for the front.
Old Sep 30, 2004 | 10:44 AM
Bigkahuna808's Avatar
I got the fronts from wheelers offroad. Perfects fits, they only pain is getting the orgnal ones off. I had to use a big ole monkey wrench, PB blaster, and a hammer. But the wheelers ones screwed right in after that
Old Sep 30, 2004 | 12:52 PM
colsoncj's Avatar
Thanks for the help and the P/N's. Anyone here have any experience with lower control arm bolts being stuck?
Old Sep 30, 2004 | 02:31 PM
mt_goat's Avatar
My UCA bolts got rusted inside the bushing sleave and I had to cut the bolts to get them off. You might want to check the price and avalability of those cam bolts before you give-up and cut them. Use anti-seize next time
Old Sep 30, 2004 | 08:17 PM
colsoncj's Avatar
Ya I figured out what the cost is. About as much as 2 cases of beer, but you gotta do what you gotta do.... Thanks for the help all!
punks_is_4x4
May 31, 2016 06:03 AM
accuracy
Sep 20, 2015 07:44 PM
Ott47
Sep 14, 2015 12:09 PM
ErikZ1220
Sep 10, 2015 04:53 AM
