wheelers wheels on backorder. replacement suggestions?
I dont know why anyone doesn't do this, but, just turn your wheels over to a side and inspect how much clearance you have between the caliper and the inside of the wheel.
Mine came with ABS and 16", with my 16" black steelies I have about .75" of clearance around the calipers. I wouldn't be able to fit any 15" rims most likely.
It only takes 5 seconds and no one ever seems to think of this?!
#26
Originally Posted by lee
nice choice.. rims will look great!
#27
i am getting a retreaded spare in the 285/75/16. drew (shotking) found a link for some, and they are only about $95 delivered. perfect for a spare.
and for the location, i have no idea yet. hopefully there is room underneat for it. if not, then i am thinking about asking eric to custom make some sort of mount using the existing rack.
#30
Originally Posted by bflooks
the cross bars, yes. but the rails should be strong enough to hold, no? can't it hold up to 175lbs?
I would go custom rack, on the roof or something
I have my full size spare in the back of my truck inside the tailgate, simple but works, maybe do something like that with a hold down or something
#31
you can just deflate it and put it underneath.
do not use the existing rack for a tire, it wont hold it.. those crossbars are REALLY weak plastic.
as for a spare, I bet that is fine a retread, however pepboys have semi aggressive off road tires in that same size for 100 bucks,,,I priced them out as that is what I am going to run once I do my body lift and spring time modifcation spree
#32
i wouldnt trust my tire or the life of the person behind me to the strength of plastic stock crossbars.
TURBOrunnerNM
07-22-2015 11:01 AM
skoti89
07-06-2015 07:45 PM
