Wheel Bearing, I think, horrible screaching noise... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-02-2009, 06:58 PM   #1 (permalink)
weiln's Avatar
Hey everyone, been a while since I posted.
Basically, 135K on my 2000 4Runner 4WD. Saturday night (yep, during Halloween), something very strange started occurring. A horrible screeching noise that I thought were the brake pad indicators coming from the front end of my truck. This was fine because I was planning on doing the brakes the next day anyway. Drove home from my brothers, screeching the whole way, then parked it Saturday night. Took it over to my parents the next day, but strangely there was no noise on the way over. Pulled the front apart, but the pads weren't even close to needing replacement. Replaced the rotors anyway as mine were warped, drove around a bit, no noise. Figured no big deal, must have gotten a rock or something in there and it was gone now.
Drove to work today, no noise. Drove around for lunch, no noise. Driving home however, after about 10 minutes on the freeway, horrible noise started. Persisted all the way home. This sparks a memory, in that the noise didn't start until after I had been on the freeway to my brothers on Saturday night either, about 20 odd minutes. Weird.
It sounds horrible, and the noise and frequency are associated with vehicle speed, not engine speed. Once the noise starts, it doesn't stop until I stop the truck, Speed up, noise increases and frequency increases. Slow down, noise quiets and frequency drops. Braking has no affect on the noise either.
Anyway, checked everything again tonight, no leaking u-joints, no CV shaft issues, boots fine. At this point, the only thing I can think is the wheel bearing on one of the sides. I don't remember feeling any play in the wheel when I had it up doing the brakes, but I could have missed something.
I don't know if this is related or not either, but I have been having a "loose" feeling in the front over bumps as well. The steering isn't loose, nothing feels loose, but going over bumps/pot holes the wheel feels loose.
Do these issues point to a wheel bearing going out, or already out? I searched the forums, but nothing really talked about a screeching sound after freeway use. It's weird that if I stay on city streets there is no issue, but freeways cause a noise.
Any ideas?
Thanks,
Nathan
__________________
Nathan
2000 4Runner SR5, V6, Auto
E-Locker, w/ grey wire mod
265/75/16 Kumho AT
Bilstein Adjustables up front
OME 890 Coils
Pics:
http://s159.photobucket.com/albums/t140/weiln/
weiln is offline
Old 11-02-2009, 07:04 PM   #2 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Get it out on the freeway, get everything good and hot. Then, drive quickly home, and put it up on jack stands. Spin the wheels and try and figure out where its coming from.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 11-02-2009, 07:04 PM   #3 (permalink)
Kiroshu's Avatar
Jack your truck up in the front and wiggle the tire top to bottom. If theres any play at all you need wheel bearings.
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
(Still working on restoring her)
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
(sold)______________
(Was my fastest truck i miss her...)
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
(was my quietest and slowest yota.)
Kiroshu is offline
Old 11-02-2009, 11:19 PM   #4 (permalink)
i had a similar screeching sound, but mine was only at low speeds, i did new pads and rotors and it was gone. my old pads were still good, so idk what was causing that horrid noise
j-money$$$ is online now
Old 11-03-2009, 05:51 AM   #5 (permalink)
BigBallsMcFalls's Avatar
wheel bearings usually make a loud low rumble or grumble when they are falling apart....
screeching ? sounds like belts or brakes
BigBallsMcFalls is offline
Old 11-03-2009, 07:12 AM   #6 (permalink)
weiln's Avatar
Yes, that's why I though brakes first too. Belts I would understand, but there aren't any belts that are vehicle speed dependent, not engine speed.
I'm hoping today to try DeathCougar's method and hopefully isolate the noise. I don't remember any play in wheel at all when I replaced the rotors this weekend, so I don't know.
Thanks!
__________________
Nathan
265/75/16 Kumho AT
OME 890 Coils
Pics:
weiln is offline
Old 11-03-2009, 07:27 AM   #7 (permalink)
hross14's Avatar
check to see if the backing plate is to close to the rotor?? either on the top or the bottom. You might also want to check your idler bearing for the belts and the fan bearing, alternator--see if you got wiggle in those little guys. Maybe what you are hearing is one of those.
__________________
Yes, I said "country." America really is a nation, but you couldn't convince those who lead the Democratic and Republican Parties of that. Both parties now see America as nothing more than an economy, a marketplace, and not a sovereign nation. They don't see you and me as citizens of this great nation; they see us as units of labor, consumers and taxpayers.
Yes, I am here to collect my 238$ worth of stock from AIG.
"What do you mean a free market economy doesnt apply to the rich?"
hross14 is offline
Old 11-03-2009, 08:06 AM   #8 (permalink)
Yukon's Avatar
Check your brake wear indicators, they screach when they get close to the disc,
Yukon is offline
Old 11-03-2009, 12:56 PM   #9 (permalink)
One more thing to throw out there is the center support bearing for your driveshaft. I replaced mine about a year ago, and now the squeal is starting again. But mine also makes noise at lower speeds.
LanceN is offline
Old 11-03-2009, 01:13 PM   #10 (permalink)
tj884Rdlx's Avatar
wheel bearings usually make a growling sound. but still could be. you been through salt water lately? or, could be as simple as a rock stuck someplace and grinding. if you're having trouble isolating the sound, get it hot so it does it continuously, then get someone to drive it in a tight circle around you, like in a parking lot, so you can listen to which side it's coming from (without having to run to keep up with it. you just turn)
a belt that gets hot and starts slipping once it expands could be doing it too, but you'd hear it coincide with the pressing of the gas pedal, y'no?
__________________
88 4Runner DLX, 15x8 soft8s w/ BFG 33x10.5 A/Ts. 1.5" SDORI spacers, OME CS009s, 1" 4crawler b.l., original Canback top
tj884Rdlx is offline
Old 11-03-2009, 01:48 PM   #11 (permalink)
weiln's Avatar
Still at work so I haven't had a chance to check, but sounds very much like the backing plate on the rotor. However, I didn't see anything, and I can't figure out what would cause it to happen only after having driven at freeway speeds. Actually, that part I can't figure out at all.
Thanks again for all the ideas, and I'm really hoping it's not a bearing, I really don't want to replace one. I live in Phoenix, so the truck hasn't even seen water for months, so no salt water or anything.
Thanks again for all the ideas!
Nathan
__________________
Nathan
265/75/16 Kumho AT
OME 890 Coils
Pics:
weiln is offline
Old 11-03-2009, 02:00 PM   #12 (permalink)
The Ruckus's Avatar
As mentioned, a shot wheel bearing sounds more like a helicopter in your wheel well than a screeching noise. I vote for backing plate as well. Maybe caliper related? Heat causes expansion, which may in turn be causing a caliper piston to "swell" (if you will) and get sticky after sustained use and slowing from higher speeds. Surface road driving = slower speeds and shorter braking distances, possibly not giving the thing a chance to get hot enough to act up, allowing things to stay in/settle back into place. Just a thought.
__________________
2000 4Runner Ltd - 150k on body, 100k on motor
ISR/Deckplate mods
sans-running boards
Stillen/magnaflow exhaust
otherwise stock
The Ruckus is offline
Old 11-03-2009, 03:40 PM   #13 (permalink)
Staff
Quote:
Your point would be valid........IF 4Runners didn't have a one piece driveline without a center support bearing!
__________________
Old 11-03-2009, 09:02 PM   #14 (permalink)
weiln's Avatar
OK, figured out the problem. I guess I was suffering from bouncing sound waves. Drove next to my dad, listened harder, sounded like it was coming from the rear. Just because it is easy to test, jacked up the rear and put her in gear, and instantly the sound was there. Turns out, it was the front u-joint in the double-cardan (I think that's what it's called). The u-joint is probably shot, but took it down, put some grease in it, and all the u-joints in the shaft, and the noise is gone.
However, I'm thinking there had to be damage to the u-joint, and now it's a matter of time before it gets worse or fails. But, this is way better than a wheel bearing...
Thanks again for everyone's help and ideas.
Nathan
__________________
Nathan
265/75/16 Kumho AT
OME 890 Coils
Pics:
weiln is offline
Tags
4runner, applying, bearing, brakes, causing, driveline, horrible, hot, loose, night, noise, runnercom, screeching, squeel, toyota, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
