weird texture on dipstick
Old 07-10-2003, 08:40 AM
Amir904's Avatar
i was checking my oil yesterday and there is some weird substance on my dip stick when i check the oil, its rust colored and slimy. oil is fine, not dark at all, i have 76k miles. but i dono what this stuff is, anyone have any idea? i am due for an oil change, 3200 miles, but i shouldnt be seeing this stuff, should i?
Old 07-10-2003, 08:42 AM
rimpainter.com's Avatar
A picture speaks a thousand words.
Old 07-10-2003, 09:04 AM
BT17R's Avatar
Too many variables to say right now, so fallback to "it depends".
How long (timewise) since your last change? What is your typical trip length? If less than 10 miles in chilly Pittsfield, it may just be normal grunge found during Winter operation. What brand and weight oil do you use? OEM Toyota oil and air filters? Changed with the oil every time? What does the coolant look like? Have you owned the rig since new? Can you easily pull a valve cover to look for sludge buildup? When was the PCV valve replaced? Is the EGR working properly? Anything besides steam coming out the tailpipe at cold start and after warmup?
We'll narrow it down, and it'll probably wind up being normal, but those are a few things to consider for now.
pickle6415
04-14-2021 06:20 AM
Davebarbier
11-03-2015 03:28 PM
zombie_barbarossa
10-02-2015 10:54 PM
JamesDINAN
09-22-2015 05:37 AM
viesail
09-05-2015 04:23 AM
Quick Reply: weird texture on dipstick
