Weird noise when braking
This is kind of hard to explain...but after driving for awhile without braking at all, if I lightly tap on the breaks I hear a clicking kind of noise from underneath the Runner...it doesn't happen everytime, only after I haven't used the brakes in a while; and it typically doesnt happen if I just slam on the brakes, only if I lightly press on them.
It's really weird, gonna be pretty hard to diagnose.
Just thought I would see if you guys had ever had this problem.
Fink
Fink
Not trying to sound like a smarty pant, but maybe your keys in the ignition? I had the same thing on my own and when I held the key chain the sound went away.
No, its a very mechanical type sound and I don't hear it with the windows up, well, I do but...I can just tell its coming from underneath the rig. Not sure what it would be.
I know on my moms Honda Pilot, those are supposed to make noise, but this hasn't done it the whole time so...its something new. I just had the brakes worked on not too long ago, about 2-3 weeks...had the front pads replaced then went back about 4 days later and had the rotors resurfaced and cleaned and all that jazz...maybe they did something to it then.
Fink
Fink
Fink
Fink
well, here's my .02
your brakes are more worn down than they used to be...
new brake pads rub against the rotor ALL of the time...
with slightly worn brake pads, there is less friction 'holding the pad in place'
therefore, when driving for a while without using your brakes, the pads are all of the towards the bottom of the caliper 'socket'... where the pad rests.
when you hit the brakes, there is just enough movement to pull the pad to the top of the caliper... and that is metal/metal, so there might be a click noise.
eh, sounds feasable, but that's pulled right out of my ass haha
Originally Posted by crappled
well, here's my .02
if they aren't oem, i wouldn't guarantee a proper fit *shrug*
hell, i like how it sounds :p
Fink, any update on this? This recently started happening to my truck. Its EVERY time i step on the brake pedal. If you roll down the window its very noticeable. I had new OEM pads put in last year if that helps. Thanks in advance guys!
I would say sheared caliper pins allowing caliper float, happened on an old Mx6 racecar we ran with...but with Toy's brakes being COMPLETELY different, they dont have the same stresses on the caliper slide ins...so, you got me.
I used to get this clicking noise when I changed brakes/rotors. I just took the brakes back off and reversed calipers and it's gone. I'm sure this noise is coming from the front brakes if anything. Hope this helps
No update on this, had my rig worked on recently and nobody noticed anything and quite honestly it hasn't caught my attention much recently either...granted it's getting cold so I don't have my windows down as much as before.
The only parts I put on my rig are OEM with the exception of the ISR mod and all that...so the brakes are all OEM. I'm assuming if it was a problem my guy at the shop would have told me about it.
If it progresses I'll have them tear em apart and look at em.
Brakes are working great though so no worries there.
Fink
Fink
genuinegemini
08-03-2015 04:56 PM
icentropy
07-14-2015 10:23 AM
