Water pump gasket
taking apart the whole front timing belt area of the motor. Why would you be doing just the gasket? It is going to be a lot of work pretty much same exact thing as doing a t-belt service.
Here you go, and if you're going to all that work I would use a new timing belt and water pump
http://www.4x4wire.com/toyota/maintenance/timing_belt/
09-04-2015 09:27 AM
