Water pump gasket
What is all is involved in replacing the water pump gasket on a 3.4L engine?
taking apart the whole front timing belt area of the motor. Why would you be doing just the gasket? It is going to be a lot of work pretty much same exact thing as doing a t-belt service.
Here you go, and if you're going to all that work I would use a new timing belt and water pump
http://www.4x4wire.com/toyota/maintenance/timing_belt/ |
Originally Posted by eric-the-red
(Post 50864572)
