Tranny problems
Old 06-04-2006, 06:32 PM
N Miltner's Avatar
Unhappy Tranny problems
I'm trying to get some help for my 99 4runner. I noticed that my auto tranny was slipping. When I pulled over to check it, it died and I can't start it. Is their some sort of safety switch that prevents me from starting the 4runner until the tranny is addressed? If its a matter of low fluid, how do I know how much to add if I can't start it? Any ideas would be appreciated. Nick
Old 06-04-2006, 07:03 PM
ebelen1's Avatar
I'm no mechanic so take the following w/ a grain of salt. I first would start w/ checking my tranny fluid if you really think this is the reason that your truck won't start. There is a line, which shows what level your tranny fluid should be when cold. If it's low according to the line, add fluid.
Old 06-04-2006, 07:07 PM
N Miltner's Avatar
Tranny problems
Thanks, Edwin. I thought that meant cold like if you just started it. I thought the 4runner had to be running to check the tranny fluid level. No? Nick
Old 06-04-2006, 07:11 PM
ebelen1's Avatar
To check it properly, it should be running but if can't get it to start, you should try this first. There's also a post on the proper way of checking this fluid as you don't want to under or over fill. I'm sure somone with the proper info will chime in.
881stGenRunner's Avatar
yes it should be running when u check tranny fluid for it to be accurate.
Old 06-05-2006, 05:53 AM
N Miltner's Avatar
Thanks for the input.Anybody know if or how low tranny fluid would prevent me from starting the 4runner?
Dieselmann
02-19-2019 02:57 AM
shadowbirdie
07-21-2015 10:38 PM
Iceman4193
07-15-2015 04:48 PM
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Tranny problems
