Testing a fuel injector
I've searched for this and found some information, but I must be doing something wrong.
I am have been troubleshooting a "cylinder 1 misfire" code.
I've already changed the plugs/wires and swapped the ignition coils with 1 and 3. After the ignition coil swap the code still points to cylinder 1.
I have a multimeter than that I set to 200 ohms and placed both leads on the fuel injector contacts, but I don't get any reading. Doesn't matter if the ignition is on or not.
1996 4runner Limited
3.4 V6
Am I missing something?
Thanks!
3.4 V6
Thanks!
Start the truck and take an extension and touch it against the fuel injector on that cylinder. It will act as a stethoscope and you should be able to feel the injector clicking if its working properly.
pyramid
07-30-2015 10:05 AM
HookahRoo
07-20-2015 07:06 PM
