Testing a fuel injector
I've searched for this and found some information, but I must be doing something wrong.
I am have been troubleshooting a "cylinder 1 misfire" code. I've already changed the plugs/wires and swapped the ignition coils with 1 and 3. After the ignition coil swap the code still points to cylinder 1. I have a multimeter than that I set to 200 ohms and placed both leads on the fuel injector contacts, but I don't get any reading. Doesn't matter if the ignition is on or not. 1996 4runner Limited 3.4 V6 Am I missing something? Thanks! |
Start the truck and take an extension and touch it against the fuel injector on that cylinder. It will act as a stethoscope and you should be able to feel the injector clicking if its working properly.
Is it reading open or shorted? What does the screen show?
Sounds like a dead injector to me, but do what Trailmix suggested to confirm. Is the engine constantly missing or is it intermittent?
