Tap the brakes and the marker lights come one?
Old 11-30-2004, 07:22 AM
Boosted Chemsit
Guest
Posts: n/a
I got a 94 22re pickup and it just started turing the marker lights and the dash lights while i hit the brakes, even with the car off it does this. I had a harness for towing originally hooked up and thought the problem might of been related to this so i removed it and still it still does this.
Any suggestions or ideas would be great.
Old 11-30-2004, 07:42 AM
Flamedx4's Avatar
Does it do this with the lights on also?
Do the brake lights work?
Do the turn signals work?
Do the marker lights work? (come on when you turn on the lights?)
Did you disconnect or rewire anything for the tow plug?
Did you rewire anything in the dash? Stereo, some accessory?)
First thing I would check is the brake light bulbs/sockets. Pull em, clean the socket, clean the bulb base. Maybe just pop in a new bulb for a test (they're cheap.)
Old 11-30-2004, 09:04 AM
TacomaTRD's Avatar
Check for a grounding or corrosion problem at the light in question. Usually it's the 4 to 3 towing adapter has gone bad...
Old 11-30-2004, 10:58 AM
4Crawler's Avatar
Likely a bad ground. Why? Because the marker light and the brake light are the same light bulb (dual filament) and share a common ground connection. If the ground connection is bad, one filament can find a path to ground through the other filament. Hit the brakes and the brake filament grounds through the marker filament and you get what looks like a marker light (dim vs. the bright brake light). Turn on the parking lights and you'll probably find if you hit the brakes, the light goes out all together. Why? You have 12V on both sides of the lamp, i.e. both filaments are at 12V, no voltage difference, no path to ground and no light.
ashersullivan88yota
01-18-2022 05:37 PM
fountain
12-31-2015 06:08 AM
09-04-2015 09:27 AM
Johntom240
7
07-13-2015 12:18 AM
razorman8669
07-12-2015 12:13 PM
Quick Reply: Tap the brakes and the marker lights come one?
