stutter at idle, engine dies after throttle blip
Old 07-25-2014, 06:08 PM
toytaco97's Avatar
I just replaced knock sensor and knock wire. All new gaskets, followed the book except for fuel pressure relief procedure. Instead I just loosened the banjo bolt and let the fuel system drain. I did loosen/remove fuel cap to relieve in tank pressure. Did not disassemble fuel rail and injectors, leaving the unit intact. Everything sat for approximately 4 days.
Installed everything correctly, as it came off. Double checked all plugs to verify connection.
Not sure if there is a specific way to repressurize the system/fuel line that I was not aware of.
1997 Toyota Tacoma 3.4l 4x4, stock everything.
Last edited by toytaco97; 07-25-2014 at 06:09 PM. Reason: forget important details
Old 07-25-2014, 06:13 PM
rworegon's Avatar
Cranking engine pressurizes the system. Check for loose grounds/electrical connections are tight and be sure all vacuum lines are on in the right place. There is a small vacuum tube that connects to the driver side head near he fire wall that is easy to miss. Is the check engine light on?
Old 07-26-2014, 06:17 AM
toytaco97's Avatar
I checked all connections, grounds and vacuum. There is a split on the hose leading from the left head to the intake plenum. CEL is on. Truck has trouble starting off crank, need to press gas pedal for start - never had to do this before.
Old 07-26-2014, 08:19 AM
toytaco97's Avatar
Doesn't start now.
I again thoroughly checked all connections, and they're all good.
Could this have anything to do with knock sensors or knock harness?
kazuya2416
04-05-2024 02:17 AM
smthwsn357
12-04-2023 02:08 AM
Charecter1
11-06-2023 10:08 AM
sandyota
02-04-2021 11:16 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: stutter at idle, engine dies after throttle blip
