sputtering 22RE??
Old 09-10-2004, 02:37 PM
bain's Avatar
sputtering 22RE??
ok,my runner has been sputtering and missing for a while now. so i replaced the fuel filter, plugs, wires,cap and rotor, fuel pressure regulator and put new OEM fuel enjectors in it...and it still sputters :pat: what else could it be?
Old 09-10-2004, 02:41 PM
evilcow's Avatar
Did you check the trouble codes?
Old 09-10-2004, 02:57 PM
bain's Avatar
yup..its showing none
Old 09-10-2004, 05:18 PM
yotafreakshow's Avatar
Read this thread: https://www.yotatech.com/forums/f116/22re-crank-case-pressure-blowing-dipstick-out-40614/
Maybe something like a burned valve?
Old 09-10-2004, 06:14 PM
bain's Avatar
gheesh i hope not
Old 09-10-2004, 06:17 PM
seaflea's Avatar
Have you checked the cap and rotor? I know every now and then that my cap button get destroyed for some reason. also check the wires for resistance. The Haynes manual should tell yopu how to do it. (although I have checked mine and they are out of range but still work fine)
Old 09-11-2004, 05:52 PM
Check your compression. There are many secrects hidden in it's wisdom.
Old 09-12-2004, 01:54 PM
bain's Avatar
ill test it this week.. i noticed it revs smooth with nice response, but ass so as i start driving it it sputters and it backfires a tad
Old 09-12-2004, 04:44 PM
SoCal4Running's Avatar
Check to make sure all your fuel injector electrical plugs are tight on the injectors, we have one with a broken clip retainer and sometimes it falls off.
Old 09-12-2004, 05:08 PM
bain's Avatar
will do
Old 09-13-2004, 04:38 AM
HondaTec521's Avatar
Backfire is usually a timing problem.
Old 09-13-2004, 06:59 AM
colsoncj's Avatar
I vote timing check and compression check....
Old 09-13-2004, 01:10 PM
bain's Avatar
its in the process of getting the tps adjusted and timing set...let u know 2marrow
Old 09-15-2004, 05:16 PM
evilcow's Avatar
so whats happening?
Old 09-16-2004, 01:03 PM
bain's Avatar
still sputtering im going to try the fuel pump next
Old 09-16-2004, 01:25 PM
colsoncj's Avatar
are you going to change the pump, or just check the pressure?
Old 09-17-2004, 04:24 AM
bain's Avatar
well,i found the complete fuel pump with 50K on it for $21 on ebay so i got it..
Old 09-17-2004, 05:17 AM
seaflea's Avatar
If you talk with Mike , he has a fuel pressure regulator tester and some other nice gadgets to help diagnose youre problems. Last I talked with him, he had his garage just about in order to start working on some stuff.
Old 09-17-2004, 01:14 PM
bain's Avatar
maybe if these hurricanes would leave us alone i could get up there.we're supposed to have another one next weekend and plus i have to build J's sliders...i dont have time for crap maybe i can get up there one day this weekend..
Old 09-17-2004, 02:53 PM
seaflea's Avatar
Yaeh, I think everybody is tired of the waether around here. J's gotta have his sliders and I've gotta have mine and I know Mike Needs his.
I guess You wont have time to fix it!
Quick Reply: sputtering 22RE??
