Snap On Tensioner Tool YA9730 for Timing Belt Replacement
Hello, anyone in the SoCal area who can loan their Snap On Tensioner Compressor Tool YA9730? Need for a timing belt replacement as I hear it makes life much easier. Will buy you a drink Thanks!
For reference, here's a link to the tool: http://buy.snapon.com/catalog/item.a...store&tool=all
No need for this tool if your kit includes the hydraulic tensioner or if you pull the compressor bracket and remove the tensioner before compressing it in a vise.
thanks, rworegon! I've looked at several instructions and some say it saves a boatload of time, while others say you don't need it. have you changed your timing belt before? would definitely appreciate any other insight or lessons learned.
Yes, I do my own TB changes, HG, etc. on my 5vz-fe 3.4L.
A recent thread...take a look at the links in post #4:
https://www.yotatech.com/forums/f2/d...pulley-281474/
This one has pictures from the FSM (Factory Service Manual):
https://www.yotatech.com/forums/f2/h...t-3-4l-140078/
just finished my timing belt replacement this past weekend. since I replaced the tensioner and idler pulleys, didn't need the snapon tool.
however, i get a squeaking sound that intensifies when i push the gas -- thinking it has something to do with the drive belts either being too tight, or not tight enough. any ideas on what the problem might be?
voiddweller
19
05-02-2016 09:10 PM
B. Graves
07-03-2015 04:10 AM
crazypaint
06-23-2015 03:27 AM
