shock question
I dont honestly know. I imagine at worst you'd have to take one end of the shock off and slip the boot on. Incidently, you dont have to lift the truck and remove tires to remove shocks...
My question is in regard to sway bars....do you have to lift the truck to disconnect them?
you have to take the shocks off to put new boots on.
Originally posted by doink
i knew that much, but i was meaning, like, is it a hard process? it looks like i can just take off the top part and slide the boot on....i could do this myself right?
You should be able to just take off the top nut on your shock and slip the boot on and bolt it back up without taking your wheels off or anything. You might have to take the lower bolt off if you cant compress it enough to get it out. Still no biggy though.
Luvmeye22re
08-04-2015 03:53 PM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
