Service Engine Light???
Old Nov 28, 2005 | 12:32 PM
rshe's Avatar
Just replaced the plugs in my 1996 Runner 3.5 and when I restarted the service engine light came on.. I have checked all vacum lines to make sure I didn't pull any off in the process...Any suggestions...
Old Nov 28, 2005 | 01:52 PM
Tacoma Dude's Avatar
Service engine?
Check engine light you mean?
Like this?
Either go to a shop that will read you the code OR get yourself an OBDII diagnostic tool and find out what your CEL code is. You'll be able to troubleshoot your issues better.
I'd suggest that once you know what it is to try searching. Check engine lights run rampant and have been covered a multitude of times.
Old Nov 30, 2005 | 01:22 PM
rshe's Avatar
Is disoncecting the battery the best way to reset this thing... Just want to check and see if it was a fluke from the tune up...
Old Nov 30, 2005 | 01:49 PM
Bassinfool's Avatar
What year / model truck do you have???
Old Nov 30, 2005 | 02:19 PM
If it is the check engine light disconnecting the battery for a while should clear it.
Bassin - his profile says 96 4runner dunno if it's a 6 or 4 banger though.
Old Nov 30, 2005 | 05:32 PM
rshe's Avatar
Sorry,
Its a 96 3.4 6 cylinder...
Old Nov 30, 2005 | 08:22 PM
rshe:
Unplugging the battery *should* clear the CEL but depending on what it is it can come back right away. You should check out your local auto supply store and see if they'll pull the code for you. That will get you a much better idea of what's going wrong under the hood.
Old Nov 30, 2005 | 09:01 PM
Fink's Avatar
Definitely get the code pulled.
Fink
smthwsn357
May 1, 2024 07:28 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Johntom240
7
Jul 13, 2015 12:18 AM
colinmil
Jul 6, 2015 04:03 PM
