replace head bolts on '88 3.0V6?
Old 12-29-2004, 01:26 PM
rivercat's Avatar
hi all-
i have a '88 V6 that has a blown head gasket at the moment, it has almost 240,000miles on it. at 160,xxx toyota replaced the head gaskets per the recall. should i replace the head bolts when i do the gaskets, as apposed to reusing them? i can't afford ARP head studs and was looking in a $50 set i think i saw on ebay. is this a totally bad idea? [ebay car parts]
Old 12-29-2004, 04:07 PM
roger's Avatar
I would replace them. If the set on ebay is new and Toyota OEM, then you should have no trouble with them. If not, buy the OEM bolts (assuming they're cheaper than ARP).
Old 12-29-2004, 04:18 PM
MonsterMaxx's Avatar
These are a torque to yield type fastener. You should only use them once.
The factory manual even says replace them.
They will NOT be replaced if you have a head gasket warranty done.
They did HG warranty replacements 6 times for me on two different trucks.
One truck is leaking now and the other I did myself about 4 years ago and DID replace the headbolts, doing fine today.
I'd say, Yes, replace the headbolts.
Old 12-29-2004, 06:01 PM
rockota's Avatar
Never noticed that in the manual... Toyota told me they were NOT torque to yield, but I had them replaced anyway.
Skip new ones, go with studs from http://www.engnbldr.com/ . I'm 99% sure he has them, even if not on his site. If he doesn't get 'em from Tim @ doa racing eninges. Better and likely cheaper than the head bolts.
bkg
Old 12-30-2004, 07:45 AM
LOL
Tim at Dead On Arrivial?????
Don't buy anything from that crook.
Old 12-30-2004, 08:29 AM
rockota's Avatar
I had a great experience with Tim on my 3.0... Regardless, they're just studs... how hard can it be to mess that up?
Old 12-30-2004, 08:31 AM
kyle_22r's Avatar
i've heard stuff about how they're cut
i won't go back to using bolts after using ARP studs on this new motor...they're just superior in every way(well, except price, but that's moot since i would've had to get mine from the dealer...)
Old 12-30-2004, 11:09 AM
rivercat's Avatar
thanks guy's and gals[?]
i'll look into the engnbldr set for $40, if we get some snow pretty soon that might be in my price range.... where's the best place to get quality head gasket set?
Old 12-30-2004, 11:24 AM
Yoda's Avatar
ONLY at the Dealer.
Old 12-30-2004, 03:55 PM
Bigblock's Avatar
i built three 3.0,s and reused the head bolts every time,with no problem.
Old 01-02-2005, 02:22 PM
rivercat's Avatar
thanks again guys... one day soon the 4runner will rise again! and on that day i will come for you, and we will 'wheel!
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: replace head bolts on '88 3.0V6?
