rear axle housing swap from rolled 4runner
Old 03-21-2010, 09:05 PM
Yota Yeti's Avatar
I have a 97 V6 with 4.30 gearing open diff. I picked up a 99 axle housing (drum to drum) with E locker and supposedly 4.30 gearing. The guy rolled is 4 runner and was parting out the truck and I got lucky ($300)at least I am hoping so.
I have torn it apart and put it back together, other than the diff and gearing.
The axles appear to turn fine and nothing appears to have been damaged from the rollover, however anybody have any tips on what I should investigate before I swap them out, other than confirming the gear ratio?
Old 03-22-2010, 06:58 AM
BajaRunner's Avatar
Well you'd assume the links would fail before bending the axle housing, but you can never know.
If you are unsure, I know you can simply modify your current housing by notching the pumpkin opening to accept a locking diff. I don't know if I could say "simply" since I have never done it, and it seems like some people feel its a PIA.
Old 03-22-2010, 07:12 AM
Yota Yeti's Avatar
My intention is to swap the housing and use my axles, brakes etc and keep the other axles as spairs.
6th Gear
19
12-10-2019 07:31 AM
DanStew
06-29-2015 10:46 AM
Niameyrider
06-25-2015 05:50 AM
AustinTaco
06-21-2015 09:54 AM
Leonel
06-13-2002 02:42 PM
Quick Reply: rear axle housing swap from rolled 4runner
