question about gearing and mpg
I have a 2000 4runner and in running 35 inch tires. I changed out the stock 373 gears for 529s but my mpg has actually Decresed a little bit. Just wanting a little insight on some reasons this could have happend. Everything i have read said that 529s with 35 inch tires on my year 4runner would take it back to stock mpg. What am i overlooking here?
Changing the gears and/or tires changes the formula for calculating the MPG because the odometer will be out of calibration.
Did you make any adjustments?
Your speedo is about 20-30% higher than stock. Use a gps with a trip meter and odometer to get your true readings.
No way you're getting 9mpg.
Also, forget "getting back to stock."
That ain't happening. You added a load of weight and pushed your brick at least a few inches taller which in turn kills all aerodynamics.
My guess is you're getting 14-17.
Getting the right gears to match your tire size will bring the RPM's at a given speed back to stock at a given speed, but once you put on 35's nothing will bring your MPG's back to stock
529 gears are kinda steep for 35's for running the hwy. 4.56 would have been a Lil better choice. But 5.29 gears are the better of the two when it comes to running trails and playing on the rocks. Like I was told years ago, are u building the rig for the hwy, or building it for the trails? Can't have the best of both worlds!!!!
__________________
__________________
winner winner chicken dinner... however, not everyone is willing to go that route. Not only $$$ but you don't see a lot of 3rd gen'rs going where they'd need dual cases. Me on the other hand, I need duals bad
No, I meant 4.56, but ur right on ur gearing for tires!!!! Every yota I've built I went straight to 5.29 gears, but all my builds where trailer queens! They weren't built to run on the hwy! I don't run smaller than 38's on any of my builds
XtraCab
04-12-2020 05:25 AM
Jnkml
07-06-2015 01:20 PM
