Pro's/Con's of 33/10.5s
Old 04-25-2004, 08:05 PM
  #61
wtmtnterror's Avatar
I could use something
Attached Thumbnails Pro's/Con's of 33/10.5s-04-18-04-007.jpg
Old 04-25-2004, 09:11 PM
  #62
OicnaiC's Avatar
I just trimmed my valance tonight. I left the center part to cover the radiator and cut off the ends, which are usually the part that's banged up the most.
I might make one of these as a replacement tho: http://www.duffcoenterprises.com/ima...05toyfront.jpg
Old 04-25-2004, 09:17 PM
  #63
Scofco's Avatar
Any pics OicnaiC? I need to do something with mine, it looks awful.
Old 04-27-2004, 08:40 AM
  #64
deathrunner's Avatar
I had 12.50's and switched to 10.50's . I did the swap for these reasons:
Lighter, Cheaper, Less drag on the road.
Things I miss:
Wider footrpint in the sand, Wider look on the truck
Overall, I wouldn't switch back. I air down when I hit the sand now, soon I will have long travel which will push my tires out 3 inches (enough to make up for the 1 inch lost in track width. Honestly I think my poor 4 banger is happier not having to face all of that rolling resistance. And with the money I save, I bought a taco. Really money isn't that different.
Old 10-10-2004, 10:14 PM
  #65
saxman285's Avatar
Question Help with a lift
I've been looking through the forums and trying to find as much info as I can, but I have a question. I'm looking to put 33's on my '90 toyota extended cab, sr5, but I don't know how big of a lift to go with. I want it to be high enough so that I don't have any rub, but not too high. I can't really afford a suspension lift for my IFS, so I'm looking at a body lift. Should I go with a 3" lift or just a 2" ?
Any help would be appreciated.
Old 10-10-2004, 10:55 PM
  #66
Brendan's Avatar
you could do what i did - crank the torsion bars up in front a bit and add an extra leaf in the rear. it's cheap, but you do sacrifice ride comfort. i've been considering going back to stock height with 31s lately...
Old 10-11-2004, 10:24 AM
  #67
saxman285's Avatar
well, a body lift really isn't that expensive. It's only just over $100, and the difference between a two inch and a three is only like $10. I just don't know what height I should go with.
Old 10-11-2004, 11:50 AM
  #68
wvuviv30's Avatar
I will say 2" of lift, you can run 33x10.50 on a 89/90-95...
I have BJ Spacers, OME Coils, not rubbing issues with the 33s on stock rims.
more pics and information: http://www.cardomain.com/memberpage/483537/4
Old 10-11-2004, 03:07 PM
  #69
AzStorm's Avatar
Originally Posted by Scofco
I think they look good!
I noticed something in that last photo though. Is there anyone out there who doesn't have a smashed up lower valence? We really need some sort of replacement for that which is a little stronger and doesn't require a new bumper.
Not to highjack the thread,but,try this.
http://www.cardomain.com/memberpage/668548/5
Old 10-11-2004, 04:24 PM
  #70
saxman285's Avatar
would i be better off to get BJ Spacers, and just add a leaf in the back or something? what are the pros and cons... and do they affect the ride or flexibility or anything?
Old 10-21-2004, 04:44 PM
  #71
slyang1012's Avatar
16 x 7 stock rims???
umm.. guys, would i be able to fit 33"X10.5 on stock rims?...i have no money to buy new rims! I believe the stock rims are 16x7! Please tell me it will fit! =(
Old 10-21-2004, 04:58 PM
  #72
dragr1's Avatar
33x10.50x15 will fit on a stock 15x7 rim. As far as I know, no one makes a 33x10.50x16.
Old 10-21-2004, 05:58 PM
  #73
tulsa_97SR5's Avatar
255/85/16 would be close, about 33x10, depending on how close the manufacturer is to the true measurement.
Old 10-21-2004, 06:44 PM
  #74
dragr1's Avatar
True, I think that most 255's are about 0.5" taller than the 33x10.50x15. If I remember it's about 33.3" versus 32.8".
Old 04-21-2005, 11:46 AM
  #75
ToyoRunner94's Avatar
cebby, does that navy blue 4runner have 12.5s or 10.5s?
suppra87
07-15-2021 05:15 PM
justdifferentials
14
06-11-2017 08:36 PM
voiddweller
10-02-2015 07:47 AM
myotherrideisayoshi
09-29-2015 05:41 AM
Odin
09-26-2015 06:56 PM
Quick Reply: Pro's/Con's of 33/10.5s
