Pass side window motor intermittent problem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-22-2005, 11:26 AM   #1 (permalink)
Send a message via ICQ to Hugo
The other day, my gf noticed her window wouldn't go down anymore. She tried using her switch, I tried using mine, nothing worked.
I figured I needed another window motor (or regulator or whatever you call it), so I called the stealer... Ah-ha! 475$CAN.
WTF???!
The thought of having a truck with a permanently closed window began to sink in, but then... I picked up the kids from school the other day and all of a sudden I noticed the girl had opened the window.
The day after, no dice, it wouldn't work.
Then, just recently, it was working again.
Has anyone ever had that happen? Would could cause this? Clearly the switches are not faulty, because both of them either work or don't.
Truck is a 99 BTW.
TIA
__________________
Hugo Lafreniere
1999 Toyota 4runner SR5 V6 5 speed - not stock - sold FTL :(
1999 BMW ///M3 convertible 5 speed - not stock
2005 Subaru Legacy GT Limited Wagon 5 speed - not stock
Hugo is offline
Old 06-24-2005, 11:08 PM   #2 (permalink)
Mine does the same thing but I've tracked it down to a loose connection in the drivers side master control switches. Sometimes the switch contacts get dirty from contact arcing and if you're really careful you can open the switch and clean the contacts without breaking the locking tabs. They're silver plated and clean up well.
Paul
Dryheat is offline
Old 06-25-2005, 06:45 AM   #3 (permalink)
leebee's Avatar
im no sure if it would be related to the drivers side controls. my pass switch is intermittent also, i removed it, cleaned it up and reinstalled it only to have the same intermittent operation. the drivers main control always works, make sure you havent accidently pressed the window lock button. dont ask how i know that.
lee
__________________
93 sr5 v6 auto, 4x4
Photos http://s866.photobucket.com/albums/a...albumview=grid
there are quite some attractive ladies on here with Toys. (compliments of ironmike)
ifsc 3(.0)
http://tlca.org
www.of4wd.com
www.sontt.com
leebee is offline
Old 06-25-2005, 09:55 AM   #4 (permalink)
I'm having the same type problem only all my windows lock up it seems opening and closing the door can trigger them to work again, although only temporarly. I ve noticed the locks don't work either when this happens. used some electrical cleaner /spray on driver side switches but didn't really help. I hate electrical issues as there are way to many wires to be chasing. If anyone knows anymore please do tell.
Suzukipro
suzukipro is offline
Old 06-27-2005, 06:28 AM   #5 (permalink)
Well, I do know that I first realized it worked again after pressing/depressing the window lock button. It's always in the unlocked position though, don't worry, I ruled that out early on.
I will dismantle the doors, remove the switches and clean them.
Weird issue though.
__________________
Hugo Lafreniere
Hugo is offline
Old 06-27-2005, 07:09 AM   #6 (permalink)
payyourtoll's Avatar
Quote:
Paul, do you have specifics on this? How to get the switch panel out? How to clean the contacts?
thanks
__________________
Rob
payyourtoll is offline
Old 06-27-2005, 10:20 AM   #7 (permalink)
Quote:
thanks
Actually, when you remove the door panel (unclip it, remove screw in the handle, unclip the little door opening thingie from said handle), you can reach from underneath and pop it out. It's either the rear goes in first or the front, I dunno, so it's better to do it from underneath, so you don't break anything.
I *think* the Haynes manual covers this.
__________________
Hugo Lafreniere
Hugo is offline
Old 06-27-2005, 01:00 PM   #8 (permalink)
leebee's Avatar
you can gently pry up the front end then slide the entire assy forward. there is enough harness to pull out to get at the plug. one word of caution, pay very close attention to the SMALL PARTS that are inside the switch. a pair of fine needle nose pliers will come in handy to get those little springs back into place. use an eraser on the end of a pencil to reach inside the switch to clean up the contact points. do one at a time so you have a point of reference when reinstalling. PATIENCE is a must when doing this! those little springs can be very difficult to get back into place.
lee
__________________
93 sr5 v6 auto, 4x4
ifsc 3(.0)
http://tlca.org
www.of4wd.com
www.sontt.com
leebee is offline
Old 06-28-2005, 12:19 AM   #9 (permalink)
The most important part is not to break the locking tabs when taking it apart. The second most important part is not to lose the springs. If both master control and passenger side control don't work I would think that its a loose connection somewhere. When I had intermittent problems I was parking my car at work and the passenger window refused to go up. In desparation I smacked the side of the armrest and it started working. Good luck.
Paul
Dryheat is offline
Old 06-30-2005, 03:35 PM   #10 (permalink)
I have all windows now working (at least for now) with the exception of the rear passenger window. Does it seem too strange that my motor would go out in the rear passenger door while I'm already having other window probs or may they have caused it to go bad?. Actually I still need to test the motor (Any tips besides taking off other door panel and conneting?) Hopefully its another short in the rear passenger door, Although this may be harder to fix than replacing the motor.
Tags
4runner, control, intermitt, intermittent, master, motor, power, problem, stuck, toyota, widow, window, windows, working, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Need help replacing Pass. side front window INsr5runner 95.5-2004 Tacomas & 96-2002 4Runners 0 07-11-2007 06:19 AM
passenger side power window problem squishy321 86-95 Trucks & 4Runners 3 09-11-2006 05:01 PM
help with power window motor,drivers side front busbeepbeep 86-95 Trucks & 4Runners 0 04-18-2006 06:36 AM
Passenger side power window switch problem ElwayLite 95.5-2004 Tacomas & 96-2002 4Runners 11 12-17-2005 10:07 AM
Getting a clunk on pass side under breaking. lilwily 95.5-2004 Tacomas & 96-2002 4Runners 5 11-16-2005 06:39 PM
2009 InternetBrands, Inc.
