Painted the motor....PICS!!!!!
1 Post
That is a Chevy 350. Well, we had to take the intake off because it was leaking oil like mad. We wanted to paint it, because it didn't look too good, so we took the radiator and accessories off and were going to paint it sitting right there. But I wanted to do it right, and it's nothing to get this motor out (unlike a 3.0) so we went ahead and yanked it out. We also wanted to take it out because the guy "jimmy rigged" alot of stuff on it because he got tired of working on it. He basically did enough to get it running. We had to redo all the wiring, hoses, etc., so it could be done right. Thanks for all the feedback guys!
Looks real good
is there an engine mount and tranny adapter to allow a small block chevy to drop into say a 95 4 Runner that originally had a 3.0
is there an adapter to allow it to mate to the 5 speed?
thanks
thanks
Originally Posted by BOSTON4RUNNER
Looks real good
thanks
thanks
how long have you ran those headers they like to crack around the welds some blockhuggers would work better
1 Post
Right now it is getting 13-14 mpg. Not too shabby, given the motor that it is. We just took the old Holly dual line 650 cfm off and put an Edelbrock 600 on there. Helped mileage tremendously. We were getting 7-8 with the Holly. With a little more tweaking, we should be able to get about 15. Those headers are from Downey, and have been on there for probably about 3 years. They are specially made for this swap. As you probably know, it's insanely tight around the steering column. No signs of cracks yet. They do make adapters to mate that motor to the toyota trannies, but our Runner has a 700R4, and an adaptor to make the stock transfer case mate up to it. The truck was actually a 5-speed when the 3.0 was in it, so the T-case is actually a manual one mated to an auto tranny. It works fine, you just have to be stopped and in neutral to shift into 4-wheel. The radiator is also from Downey. It works well, usually runs between 180-190 degrees. All in all, this thing has turned out way better than I thought it would. We have most of the bugs worked out, and everything is running fine. We just need to figure out how we're going to hook up the a/c!!!!
1 Post
Yea we would love to get a TBI setup eventually, but we just bought the new carb, so that will have to do for a while. It is EXTREMELY nice to have twice the horsepower with roughly the same gas mileage as a 3.0. I'm sure if we let up on the skinny pedal a little more we could do even better........lol. Can't resist nailing it every once in a while though. A 330hp 89 4Runner is definately fun to drive. It's also funny to see the looks on people's faces when you pull up in a Yota that sounds like this.
1 Post
Well, the whole thing (including new crate motor, new trans, all the necessary adapters, etc., and a 4" Pro Comp suspension and 3" body lift was about 10,000. Depending on which direction you want to go with the trans, the motor mounts, adapters, and all the other "little things" you'll need can run anywhere from 1,500 to 2,000, depending on what you want to do. This includes a new radiator.
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
Toys4parts
09-26-2015 01:56 PM
