Is this overKILL?
Is this overKILL?
On an 88 4runner. Is a 4 inch suspension lift and 2 inch body lift OVERKILL for 33s? I dont want any rubbing and i want room to flex. Will it look weird running a 6 inch lift with 33s? I am asking because im going to be running 33s, but EVERY SO OFTEN i'll be running 35s. what do you think?
Originally Posted by Tacoma750
33 inch m/ts or mudders. Probably a 10.5 wide tire
Originally Posted by Jonathan
I think it will look a little goofy with only a 10.50 wide tire. It probably wouldn't look too bad with a 12.50 wide tire.
The width of your rim will also affect how your truck looks, not just the width of your tire.
Also you said you are going to occasionally be running 35s, will that be for road use only?
I also plan on doing a similar setup, 33's for street(dd), and 35's for serious offroading. Does anybody have any pics of ~6" of lift on a first gen with 33's?
with 35s for wheeling you will need the extra clearance so less lift is not an option unless you wanna chop your fenders. For 33s with 6" lift and Bushwacker flares you'll need a tall and wide 33 like a Swamper 33" X 12.50 on a 10" wide rim. The Bushwackers will be the cut-out type?
well i cant find exactly what you're looking for but this guy has 4 suspension, 3 body and 35X13.50 tires with what seems to be some kind of extend-a-fender flares.
http://memimage.cardomain.net/member...63_15_full.jpg
his page: http://www.cardomain.com/memberpage/768363/2
Jcrawl94
10
10-24-2015 04:34 PM
