not starting - help diagnose the prob!
Old Aug 26, 2006 | 10:36 PM
uogecko's Avatar
Hi everyone - my 1997 SR5 4Runner has about 156,000 miles and has been serviced regularly. I've owned it for about a year and half.
I've been having an intermittent problem where the car is not starting.
All electrical systems come on immediately which makes me think that the problem is not with the battery. When I turn the ignition the engine isn't starting - it's not even turning over. Randomly if I keep trying it will fire up eventually.
Does this sound like a problem with the starter? How can I be sure? What should I expect to spend to fix it?
Old Aug 27, 2006 | 06:35 AM
fireteacher's Avatar
yes....starter. SEARCH for replacing the contacts on the starter..very cheap to do or replace the hole thing, not so cheap to do. i believe there is a write up in the tech section.
Old Aug 27, 2006 | 06:40 AM
https://www.yotatech.com/forums/show...arter+contacts
i searched starter contacts and found the thread, it wasnt in the maintenance section so here you go!! good luck
Old Aug 27, 2006 | 06:43 AM
uogecko's Avatar
Thanks!
Doug4320
Mar 24, 2018 10:11 PM
Yota.Jay
Jul 23, 2015 08:08 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
