My truck is really slow
Old Oct 5, 2004 | 07:47 PM
Yamaha+Toyota=Fun's Avatar
Today I drove an 86 1 ton pickup 2wd, and I was suprised at how fast it was compared to my truck. The 86 had a 22re and a K&N replacement. My truck is a 92 4wd 22re 5 speed and it is really slow compared. I know having bigger tires(31s) will slow it down a bit but it hardly pulls in 5th gear below 55mph... if at all. Anyone else running a simliar setup to mine, is your truck really that slow? Also anyone know what the best way to get power out the the 22re. I have a NWOR cam and FIPK k&n kit.
Thanks
Austin
Old Oct 6, 2004 | 05:25 PM
joez's Avatar
Get it tuned properly. After a cam and about 2 hours getting everything dialed in my 83 was actually decently quick, at least it was faster than before. Clean your injectors, make sure your fuel filters are clear, check timing, change the plugs, wires, cap and rotor.
Old Oct 6, 2004 | 05:45 PM
What plugs do you guys recommend?
Old Oct 6, 2004 | 05:49 PM
VolcomTacoma's Avatar
I would go with OEM plugs which are probably Denso or NGK.
Old Oct 6, 2004 | 06:00 PM
AgRunner06's Avatar
Do what he said then buy a header and exhaust.
Old Oct 6, 2004 | 08:09 PM
SoCal4Running's Avatar
I bet the 1ton has some pretty high gears which will make it seem like it has more hp.
Old Oct 6, 2004 | 08:36 PM
snwbrdpunk16's Avatar
u also have to remember that the 2wd prolly didnt way nearly as much as ur 4wd. thats a difference right there.
Old Oct 6, 2004 | 08:38 PM
kyle_22r's Avatar
actually low gears will give you better acceleration. however, a '90 4x4 and the '86 2wd 1 ton probably both have 4.10s(4.30s if the 1 ton has the tow package), the 1 ton has a lower profile, less weight and smaller tires so that all probably has a lot of effect
my 2wd drove like a rally car, my 4x4 drives like a VW bus!
Old Oct 7, 2004 | 12:28 AM
jimbo74's Avatar
my 85 4x2 5 speed with 3.07 gears in an 8" rear 22r carb and a huge air fliter mod short cab std bed with 31s huals butt compared to a friends 84 basically the same truck not sure on tranny other than stick, or gears, no engine mods with 30" tires
he said he has a known exhuast leak and that hurts a lot... otehr than that, he rode in mine the other day and was like wow!!!!
Old Oct 7, 2004 | 03:53 AM
evilcow's Avatar
It says in your sig. that it has a rusted out muffler. Probably has a bunged up cat too. How is the clutch? That could also be the cause.
Old Oct 14, 2004 | 08:58 AM
Well just got a new dual exhaust a coupla days ago, helped alot! Also this weekend im gonna to build an intake. Im starting to think the clutch is going to. Ill just have to see!
Jdgarrison
Oct 1, 2015 05:22 PM
MadMax48
Jul 3, 2015 08:26 AM
Mr.Black
Jun 21, 2015 10:17 AM
streetuner15
Jun 18, 2015 10:59 PM
NerfHerder-97SR5-
7
Jul 12, 2002 03:42 AM
