Front Turn Signal Power Question
Old May 3, 2003 | 08:46 AM
LSUMatt1514's Avatar
I've got a couple questions about the front turn signals on the 3rd gen....
1. Which wire at the bulb is the positive 12 volt wire?
2. Do the turn signals blink because a relay is supplying the bulb 12 volts, then zero, 12 volts, then zero, etc?
I haven't decided about installing the VW sidemarkers yet, but I found an alternative today that I might go with. Just want to clear up these power questions before starting the install.
Thanks guys. Later.
Matt
Old May 3, 2003 | 04:03 PM
WT's Avatar
WT
Not sure but a Meter or test light will help for sure. Most times its a relay that is used to make the voltages go +12V and -12V
Old May 3, 2003 | 04:59 PM
rjm's Avatar
rjm
turn signals
usually the ground wire is black or black and another color ( black with a white stripe,etc)
Old Oct 14, 2004 | 10:07 AM
timber725's Avatar
This will explain everything:
http://www.howstuffworks.com/turn-signal.htm
But it is NOT a relay. It's a simple unit called a Thermal flasher. The article explains everything clearly.
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
