maintnance service intervals
Old 08-24-2004, 01:51 PM
2001Millrunner's Avatar
I'm sure this came up before but serch did not help
does anyone know the maintnance service intervals and what's done in it?
Old 08-24-2004, 02:00 PM
ErikB's Avatar
Here's a good link for the 30K service:
http://www.4x4wire.com/toyota/mainte...a_4runner_30k/
The 30K is the biggie, most of the rest is just normal oil changes, etc.
Timing belt replacement is recommended at 60K intervals, as well as I think valve check/adjustment.
Old 08-24-2004, 02:45 PM
User 051420's Avatar
https://www.yotatech.com/forums/f123/toyota-maintenace-search-engine-online-fsm-manuals-hunter-balancers-38266/
It's a stickey in the maintenace section, and SUPER helpful.
Old 08-25-2004, 01:12 PM
this is most helpful, thanks guys!
Old 08-25-2004, 09:19 PM
spiff's Avatar
I'm at 70K miles and just had an oil change. I did the major service at 60K, the service dept said I could hold out till 90k for the timing belt.
Old 08-26-2004, 07:23 AM
ErikB's Avatar
I changed my 3.4L timing belt at 90 and 180K and both times the belt was in near-perfect condition visually. I did check it at 60 and 75K on each belt too though just to make sure. At 180K I also replaced the water pump and timing belt idler pulleys. They still seemed like they were in decent shape too, but I did it as preventive maintenance... I figure if I don't have to do those again for another 180K, that will be fine.
Corvoid
12-11-2015 11:21 AM
Dale Johnston
11
10-31-2015 10:22 PM
Boomer8404
09-24-2015 01:12 PM
PBRaddict#1
09-22-2015 07:50 AM
Boomer8404
09-20-2015 06:15 PM
Quick Reply: maintnance service intervals
