ISR mod Question...3. slow
I am in the process of doing the ISR mod. I have a turbo tube from a ford 6.0 diesel that I have cut for a perfect fit. I have seen the write up that Blu made for the mod, but I dont see one of the hoses that my truck has going to the silencer.
I have the hose coming off the valve cover, then I have 2 hoses-1 small-1 bigger hose coming from under the intake manifold. I need some pics of how you guys with the 3. slow routed these lines.
Just turn the intake hose that comes off your TB sideways and then make a piece of pipe that goes from there to the AFM. Then all you have to do is extend the breather hose that comes from the driver's-side valve cover. You should have a hose that comes from the PCV valve. Just run that hose into the new piece of pipe. Here is a pic of mine. However I used PVC but you get the idea.
I reused the old hose from the valve cover because I couldn't find an 1/2" fuel line - that's what you'll need to replace it. Here's what I did to my airbox for anyone who cares.
Agrunner--so it looks like you just attached the smaller of the 2 hoses to the intake tube and the thicker hose stayed in part of the silencer, is that right??
:bounce2:
UK--I did a search and found lots of great pics of different intakes, but none of them showed the hose I was questioning. I now have all the pieces I need, wait until you guys see this one
TheBFA
02-15-2020 06:55 AM
hiluxinargentina
09-30-2015 05:51 PM
JookUpVandetti
09-30-2015 08:58 AM
