Ignition Coil Comparison
Old Sep 26, 2009 | 09:00 AM
kvanderploeg's Avatar
I was having issues with my CEL coming on and a rough idle when the truck had been sitting out over night, in the rain, or high humidity. After 5 minutes of idle, it would run fine. I did my research on here, and found others that had the same problems, and found it to be an ignition coil. I managed to get the light this morning, so I took it to AutoZone to put the reader on it. It came back with a misfire on cylinder #6. I hadn't replaced the plugs and wires since I got it back in early 2005, so I figured I would replace wires, plugs and the cylinder #3 ignition coil (#3 coil pack feeds cylinder #6).
Bought NGK Iridium IX plugs, as it was about the best choice from what they had in stock. Also got a Bosch plug wireset. I'm not a huge fan of Bosch, but they should work. And finally, a Duralast ignition coil.
After pulling the coil off of cylinder #3, I could certainly tell there was something different about this one. It did not look good at all. Here's a comparison photo showing a good coil out of cylinder #5 on the left versus the bad coil out of cylinder #3 on the right:
I'm sure many of you have seen or dealt with this before, and I'm glad I got the information I did off of here. I didn't see any photos, however, so this may help some others that come looking for help. Here's one more photo showing a good coil on the left, bad coil in the middle, and brand new coil on the right. Thanks for all the help everyone!
Kent
Old Sep 26, 2009 | 09:19 AM
akaphilly's Avatar
so did it fix the CEL? i had the same problem with misfire at #3. i replaced the pack with an oem one. and it still didnt fix it. i tightened the spark plug but didnt replace. waiting for the ik20s
Old Sep 26, 2009 | 01:02 PM
It seems to have, although it will be hard to say until I have another damp morning. Most mornings I ride the motorcycle to work instead of taking the truck, unless it's raining. No rain in the forecast here for quite a few days.
Was the coil pack you replaced it with a new OEM or used?
Kent
Old Sep 27, 2009 | 06:15 AM
akaphilly's Avatar
the coil pack i replaced was a used ebay one. that could be my problem right there. i wouldnt have thought duralast made an coil pack. what was the price on that? i am gona try swaping them around and seeing if the misfire moves to a differnt cylinder
Old Sep 27, 2009 | 06:33 AM
It was a lot cheaper than I was finding from some other online places, $68.00. Here is the link:
http://www.autozone.com/autozone/cat...dName=Duralast
I went out to start the truck this morning, as there was a lot of dew and fog. The truck fired right up, and no stumbling, no CEL, just smooth running.
Make sure you reference the chart in the third post at this link. This is the correct cylinder numbering. The little chart to the left of the diagram of the engine shows the wireset order. 2-5, 3-6, 1-4.
https://www.yotatech.com/forums/f2/f...-4-help-47016/
Good luck!
Kent
Old Sep 27, 2009 | 08:39 AM
eddieleephd's Avatar
Did you use Di-electric????
Old Sep 27, 2009 | 08:47 AM
Good point. I just throw out those little packets they include with the wireset. Buy a big tube of it. If you have the big tube, you'll be more inclined to use it more often. It does make a difference!
Kent
Old May 3, 2012 | 11:26 AM
mirage212's Avatar
Same problem with rough acceleration and smooth idle when humid
Sorry to open this up after such a long time, but I had the same problem with rough acceleration and smooth idle only when humid in my 96 4runner. I checked all the ignition coils and one seemed intermittant and I'll replace it. However my question is this: all of my spark plugs were not torques and were only barly finger tight... there was obviously loss of compression due to this and all the coils and spark plug wires look like the picture in this thread. I really dont want to spend the $300 ($80*3+60) for 3 new ignition coils and a cable set. Bottom line is if it tests out (resistance-wise) it should be fine right? And it does not matter much how it looks? Can I clean it with something or should that not be done in the enclosed area by the spark plugs? I've been getting 16mpg for a while now instead of the 21mpg like I used to get; I want to fix this but dont want to be shot-gunning parts in when I could be replacing other stuff that might help more.
Old May 3, 2012 | 04:05 PM
Yes if the resistance is good then it should be fine, provided that you are using Di-electric grease and the proper plugs for these trucks.. Dual ground strap.... NGK or Denso in a 5 heat range BKR5ET
MadMax48
Mar 3, 2020 10:33 AM
mojo4x420
Sep 16, 2015 08:07 AM
JHalcyonM
Sep 14, 2015 01:10 AM
