Hot start stall problem...fixed!
Old 05-05-2007, 11:22 AM
BajaRunner's Avatar
I went and cleaned the Idle Air Control today, located underneath the throttle body. Went for a test drive and it seemed back to normal. It had gotten to the point that I would stall out at stop lights, and even during cold starts. :/
So I took some of the hoses off the unit, and it spewed a good 1/4 cup of liquid. It resembled brake fluid. Anyone have a clue on what it could have been?
I did the same thing as this guy:
https://www.yotatech.com/forums/f123/re-3-4l-v6-hard-start-hot-cleaned-iac-pics-92286/
Old 05-25-2007, 07:50 PM
hydrochskier's Avatar
Just curious but, where exactly is the idle air control because my 4runner will stall randomly sometimes?
Old 05-25-2007, 10:37 PM
BajaRunner's Avatar
Right underneath the throttle body. (aka Butterfly valve).. Follow the air box hose into the engine ... thats the throttle body. You take that out, and right below there is a sensor and another chamber that tends to get gunked up.
Old 05-26-2007, 08:45 AM
Thank you! Maybe this fix will solve my random stalling problems.
Old 05-30-2007, 07:53 AM
Ron Helmuth's Avatar
Thanks for posting up what the trouble was-this is most helpful to all of us fellow 4Runner owners.
glad to hear that frustration is solved.
Old 05-30-2007, 10:08 AM
gpcollen1's Avatar
Shouldnt that have been coolant? Brake Fluid ?-? in color only I guess?
Old 05-30-2007, 12:25 PM
BajaRunner's Avatar
Donno, it I think was oil.
Old 05-30-2007, 02:11 PM
Crazychopstick's Avatar
It was probably just built-up oil residue from a normally functioning PCV system.
Thanks for posting up this solution, I had my Runner stall once in the middle of rush hour on an uphill slope. So maybe I should go ahead a clean this out.
But I was wondering, should the IAC have a bit of oil as lubrication?
And, did you replace all the o-ring/gaskets?
Charecter1
11-06-2023 10:08 AM
bigjstang
08-25-2021 12:41 AM
Poncho0206
07-10-2015 06:21 PM
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Hot start stall problem...fixed!
