Which headers are compatible with a 1" BL?
Before you even start, the headers will be installed on a motor that is out of the vehicle so not so much a PIA. I just need to know which will work with my 1" wabfab BL. A SC is in the works and I feel a set of headers will compliment it.
Aaron
Aaron
Well I expected some response, but none? I have searched and nothing definitive has come up. I know some say no BL at all will fit while others say only with a 2" will you run into problems.
Aaron
Aaron
There is an alleged issue with the steering linkage and the header coming into contact with one another. Most companies will tell you NO Way but have not evaluated the big 3 BL's (1",2",3")make certain at least not to my knowledge. I'm not 100% certain on the HP gain but figured if the engine is out I mine as weel seeing the SC will be on there too.
Aaron
Aaron
1" is typically OK on the Tacomas and 3rd gen 4Runners:
- http://www.4crawler.com/4x4/ForSale/...l#Introduction
Aaron
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
