Got myself an Optima Red Top today!
Tstango-
The problem is the terminal position. Even if its mounted upright, the + and - cables will not reach. If you spin it around, they still wont reach because now the + and - posts are on the "wrong side."
That is why I flipped mine on its side. I used the stock hold down, with just a bit of modifying, and its holding tight.
Originally posted by nrgetic99
Little known fact is that spacer will go on TOP of the battery also.
Just connect it up, clip the spacer ON TOP then the stock clamp works just fine.
David
BTW, I was told we needed the Orange Top for our trucks...eg. the posts are reversed.
David
Using the spacer on top of the battery sounds like an excellent idea, by the way
justdifferentials
Just Differentials
08-15-2015 05:25 PM
Poncho0206
07-10-2015 06:21 PM
crashburnoveride
07-10-2015 06:39 AM
