Got my new bumper, What to do with my exposed turn signals
Old 08-03-2011, 01:12 PM
jumpersatthedoor's Avatar
2001 4Runner SR5
So I installed my new Savage Off-road bumper and overlooked one major thing. What am I going to do with my turn signals that came out of the stock bumper? Here is a picture of what I was thinking, but couldn't quite find the correct application of a fully enclosed sleek turn signal.
http://www.flickr.com/photos/57092665@N03/6006153593/
Any idea where I can get a two wire fully enclosed LED turn signal with a "L" bracket? I looked on autolumination but they had ones with 3 wires "dim" "bright" and "ground" which is not what I need, or can I just not hook up the "dim" wire and let it go?
Old 08-03-2011, 01:19 PM
xxxtreme22r's Avatar
photo didn't load, but you can also look into relocating turn signal into marker lights.
Old 08-03-2011, 01:33 PM
Mounting onto the fender?
Old 08-03-2011, 01:38 PM
matt92yota's Avatar
maybe this will work for you:
http://www.wabfab.org/component/opti...roduct_id,829/
Old 08-03-2011, 01:40 PM
No the corner marker lights get converted to turn signals. See my build thread or there is also a few more guys who did it as well. IMO much more clean then just adding lights that won't look like they belong on the bumper.
Old 08-03-2011, 01:45 PM
brandon16's Avatar
http://www.trail-gear.com/bumpers the led turn signals on here might work for you
I like that idea, thanks for the link. Not that mounting a turn signal to the bumper is bad or even looks bad but the less breakable stuff that I have on there the better. Thanks guys.
Old 08-03-2011, 02:02 PM
punkelberg's Avatar
I mounted mine under the headlights....
Old 08-03-2011, 02:03 PM
Elton's Avatar
keep it clean mount then in the corner lights with some amber bulbs
Old 08-03-2011, 02:14 PM
I like that idea, but what happens to the marker lights? Or is it a "who cares?" type of situation?
Old 08-03-2011, 02:38 PM
stepside trd's Avatar
If your set on mounting them to your bumper, go to a junk yard and snag some off a motorcycle. Newer bikes use LED's.....
Old 08-03-2011, 02:42 PM
if you convert to dual element bulb (1157A) like I did, you don't loose anything. Or you can just make another hole for the original bulb and run two bulbs. IMO running an 1157 is a cleaner solution.
Old 08-04-2011, 12:49 PM
Im assuming I will have to get the 1157 base to convert from the 7440 for the turn signal. Then retrofit the dual element for the marker light and the turn signal making them one connection? That is how this is playing out in my head.
Old 08-04-2011, 01:58 PM
scuba's Avatar
Take a 1" hole bit and drill another hole into the back of the corner light.
It's that simple.
Old 08-04-2011, 02:36 PM
michael1963's Avatar
Jumper - Like this for the corner markers. You keep your original wiring and bulb, just drill a 1 - 1.5 inch hole just underneath the one that is there now, place your bulb in, you will have to secure it in place (I used 2 zap-straps) but to keep water out, you could use silicon.
Old 08-05-2011, 11:12 AM
Excellent!! Can do. Thanks for the pics
Just finished. Happy with the result. Here is a video with the hazards
http://www.flickr.com/photos/57092665@N03/6012851994/
Old 08-07-2011, 08:10 AM
Excellent. Looks good and didn't cost you a cent.
Old 08-07-2011, 07:27 PM
Well, $4 for the Amber bulbs and and $17 for a new set of drill bits. (I will take any excuse to buy new tools/accessories)
Old 08-07-2011, 07:29 PM
good deal, those look bright as hell.
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
ghostmoney
01-28-2018 11:42 AM
Shoua
13
05-22-2016 05:19 AM
SMOD
07-27-2015 01:45 PM
Quick Reply: Got my new bumper, What to do with my exposed turn signals
