getting a starter problem
im about to have some start up problems..doesnt happen often..is anyone experience this kind of problem...ok..
there are times when i first start up my 4runner..it does this click!! noise.. then i try again then it starts up fine....... then jess about lastnight at work instead of jess clicking jess one time, then starting up fine..this time it click twice..on the igniton once "click" then on again second time "click" then third try..it starts..this only happens once awhile..not all the time..what may seem to be the problem..i check the battery, battery is fine..what else do think this problem is...HELP..im scared ..jess bought this rig not too long ago...
Did you search? there are already alot of threads covering this, one just last week. Now this thread will show up when someone searches for "starter problems". Threads like these make the search function less effective.
Yup its the starter contacts alright. I had the same problem. Search for a TOR, he is a Toyota Parts Rep and you can get the contacts from him for $20 shipped. Follow the write up in the tech section on the starter removal, replace the contacts and everything will be like new.
Worst use of the English language I've seen in a while. This is a common problem, read the archives. It's probably your starter contatcts. Before you ask ust how to remove it, please check the tech section and do your homework. If you still unsure please ask us. And try to use some form of grammar.
First, the contacts are a dealer part. I have seen kits on the internet but they are probably just repackaged Toyota kits. $20 plus tax. And be prepared for them not to have them in stock. They are not a priority part in the parts dept.
Second, no you don't have to disassemble the whole starter motor. The contacts are in the back of the solenoid which is attached to the starter motor.
Please search the archives and/or search on Google for Toyota Starter Contacts Replacing. There are lots of sites that have instructions on how to do it.
ZONAYODA
07-13-2015 07:17 PM
