gear oil question
Old 02-25-2007, 08:00 PM
Alexander 26's Avatar
gear oil question
Hi guys!! i have a question. couple months ago i've changed gears on my truck. i went from 4.10 to 4.56. i've driven around 3000 miles since then. i already got the gear oil changed after first 500 miles....and yesterday decided to check it. it was realy dark. no metal pieces....just a fine metal dust. is it ok??? or should i go back to the shop to have them chek it again??
thank you!!
Old 02-25-2007, 08:01 PM
oooo...by the way it's 2000 v6 4wheel drive
Old 02-25-2007, 08:27 PM
anyone??
Old 02-25-2007, 08:54 PM
Knuckles's Avatar
i dont see why it wouldnt be okay to change? IF they used synthetic gear oil to change it that may be why it appears dark.
Old 02-25-2007, 09:02 PM
Elton's Avatar
i bet its not as dark as mine with 145k on it
Old 02-25-2007, 09:04 PM
Staff
DeathCougar's Avatar
If you already changed it once, then leave it.
If you REALLY aren't feeling comfortable with the darkness, then change it again. A little peace of mind goes a long way, especially with Toyota.
Old 02-27-2007, 02:02 PM
does this look ok???
Old 02-27-2007, 02:33 PM
MudHippy's Avatar
Seen alotta gear oil in my day, looks good. That fine particulate may not even be entirely metal(the phosphorous coating also wears from the gears), and is perfectly normal. You can change the fluid as often as you can afford or definetely when the manufact. recommends.
Old 02-27-2007, 02:36 PM
thank you!!! i was realy worrying about that!!
smthwsn357
05-01-2024 07:28 AM
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
87blyota
07-10-2015 04:31 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: gear oil question
