Fog Lights problem '97 4runner SR5
Old Oct 7, 2006 | 05:05 PM
YM13's Avatar
Angry Fog Lights problem '97 4runner SR5
I recently purchased a '97 4runner with the left fog/driving light busted (but the other one is fine) The fog lights were factory installed and came with the car so they should be fine but the one foglight that is intact does not work. I checked the wiring and it is an independant circut (meaning one should light up even if the other lightbulb is out). I was wondering what could be going wrong? Could the relay have gotton wet and is not working or what? I checked all of the fuses and none of them are broken (unless there is one on the actuall wiring of the lights) and also the switch inside the car has a light that glows so i know the switch is geting power. I tested for power at the bulb and i wasn't getting any from what I could figure out (maybe i'm doing something wrong). I'm pretty novice in wiring so I could use the help if anyone has any idea. I am stressing over this badly because I hate it when I can't figure something out.....
Here's a picture of the lights i'm talking about...it's the small one on the bottom right of the car.
Old Oct 7, 2006 | 05:14 PM
Elton's Avatar
could be the relay
Old Oct 11, 2006 | 02:33 PM
Elton's Avatar
any luck ?
Old Oct 11, 2006 | 03:49 PM
YM13's Avatar
I got them fixed...it turned out to be the fuse along the actual wiring of the switch. The fuse was actually what i thought was the relay and when i went to pull it out a yellow fuse was revealed and it was broken...after i replaced it everything was in working order....
Old Oct 11, 2006 | 03:50 PM
Elton's Avatar
kool did u get a new light for the one side ?
arlindsay1992
Jan 23, 2024 01:34 PM
stunner_runner
Jun 17, 2015 05:35 PM
CLin9383
7
Jun 25, 2002 01:42 PM
MRael
15
Jun 5, 2002 02:20 PM
