Firing order on a 3.4, Help - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-12-2004, 08:53 AM   #1 (permalink)
Hey to all, got the new wires and I think I crossed the wirs. Heck there's only three, but somehow th truck doesn't seem to be running smooth when I started so before I start changing the wires around, Anybody got the firing order, which wires go to which coil pack? 1-3-5 to ........, thanks, EDH
h7009 is offline
Old 12-12-2004, 09:23 AM   #2 (permalink)
Mad Chemist's Avatar
According to my Chilton's manual, for the 5VZ-FE (97 to 2000), the firing order is 1-2-3-4-5-6, believe it or not. Standing in front of the vehicle, looking towards the back, the left bank of cylinders are numbered 1,3 and 5, and the right bank of cylinders are numbers 2,,4 and 6(front to back). Make sure everything else is reconnected, are the boot wires on tight? Maybe a bad plug as well. Good luck!
__________________
-David
'98 4Runner: SAW/OME lift, TJM bumper, Warn M8000 winch, Hayden tranny cooler, Trail Carnage front and belly skid plates, PIAA fogs, Rock lights, 33" MT's on Tech1 Rockcrawler rims, Lars sway bar discos, Sonoran bumpstops and rear bumper, RB 1" body lift, Daystar front bumpstops
'73 FJ40: 327 SBC, York, Dual Batteries, custom tire carrier, Corbeau Baja SS bucket seats, Bestop top.
TLCA#14428
Mad Chemist is offline
Old 12-12-2004, 09:29 AM   #3 (permalink)
Swede's Avatar
Does this help ya?
__________________
'98 4Runner SR5, V-6, 5-speed,
35" Baja Claws,
17x9 Eagle Alloys,
E-Locker,
3" Susp Lift,
3" Body Lift,
Elbow mod,
Deckplate Mod,
"D" gasket mod,
22" Magnaflow,
Silverstars,
Headlight Film,
67" TG Sliders,
8500lbs Portable Winch,
3rd Row Seat,
Magellan GPS...
Next on the list: 4:88 gears
Swede is offline
Old 12-12-2004, 09:48 AM   #4 (permalink)
keisur's Avatar
That out of a Haynes?
__________________
Front: 4.88's w/ ARB Locker
Rear: 4.88's w/ ARB Locker
Lift: Suspension - F: Sway-A-Way Coilovers; R: OME Coils/Shocks
Body - 2" HDPE Pucks w/ higher strength bolts
Recovery: TJM T15 Bull Bumper w/ Warn M8000 Winch
Lighting: Lightforce Striker 170's
Multimedia: Kenwood DNX5120 DVD/GPS/USB/iPod/SAT
Sound: Focal 165A1 Component Front w/ Focal 130CA1 Rear
Infiniti Kappa Perfect 10.1 Sub
500W RMS amp for fronts and rears; 500W RMS amp for sub
Power: Optima Blue Top
1400 Watt Power Inverter
keisur is offline
Old 12-12-2004, 09:49 AM   #5 (permalink)
keisur's Avatar
Quote:
Where can I get a Chilton's for our 4runners? I've looked everywhere and I can only find Haynes.
EDIT: nevermind, I found a place:
http://www.delmarlearning.com/browse...=AU&cat2ID=CHM
__________________
keisur is offline
Old 12-12-2004, 10:28 AM   #6 (permalink)
firing order
Mad Chemist and Swede, thanks, I just got a check engine light, obviously got the wiring order wrong, thanks for the help. I'll go outside and try this right now. let you all know. thanks again, EDH
h7009 is offline
Old 12-12-2004, 10:53 AM   #7 (permalink)
I believe they no longer make Chilton manuals you can only get Hayes.
bbagwell is offline
Old 12-12-2004, 10:54 AM   #8 (permalink)
keisur's Avatar
Quote:
see my edit in that post. you can get them.
and also here along with the Haynes:
http://www.amazon.com/exec/obidos/tg...glance&s=books
__________________
keisur is offline
Old 12-12-2004, 11:44 AM   #9 (permalink)
Hope you get it figured out!
__________________
-David
TLCA#14428
Old 12-13-2004, 05:55 AM   #10 (permalink)
Firing order 3.4
Hey thanks to all who helped out. "Swede" the diagram was perfect. I am sending the wires back to Sparkplug.com as they did not have the much needed retainer caps to hold the wires on. I bought some NAPA "Max LIfe" wires and they came complete. I changed the plugs and wires and the trucks now starts faster/easier and runs smoother. guess it was time and all at 56,000 miles. So much for 100,000 mile tune ups!! Again thanks to all who helped and to this board it's GREAT!! EDH
h7009 is offline
Old 06-14-2007, 09:17 AM   #11 (permalink)
Spend the $$ to buy actual Toyota OEM wires. You will eventually...
The Napa wires I had for a short time made me lose gas mileage, power, and caused lots of interference on the radio. She ran noticeably better with Toyota parts.
YMMV
funjumper is offline
Old 12-09-2007, 10:46 AM   #12 (permalink)
8lugnuts's Avatar
I realize this post is old but my problem is new and similar to h7009’s. I
replaced the wires + plugs on my ’96 T100 3.4L yesterday(NKG dual electrode
plugs, Bosch wires). When I fired it up it sputtered & shuttered, miss-fired, but
would idle. I swapped the wires on cyls 1 & 3 thinking I mixed them up.
Same thing.Then I then discovered I left he coil disconnected on cyl. 5,
so I reconnected it. Still same thing. I re-swapped wires on 1 & 3 so now I
have wires as such:
1 - 2
3 - 4
5 - 6
The motor will not even start now. On the Haynes diagram in this thread,
does the little box to the left of the cylinder diag. show which cylinders the
wires are supposed to be connected to?
1 - 4
3 - 6
2 - 5 ???
Thanks.
8lugger
8lugnuts is offline
Old 12-09-2007, 11:06 AM   #13 (permalink)
8lugnuts's Avatar
I think I found my answer on the thread below. I'll know for sure
when I get home an hour or so to try it.
http://www.yotatech.com/f2/help-havi...k-plugs-40801/
__________________
thanks,
8lugnuts
'96 T100 SR5 xCab 4X4 3.4L, stock(for now...)
'93 Dodge Ramcharger SE 318MFI
'88 Jeep Cherokee Pioneer 4dr 4.0 I6
8lugnuts is offline
Tags
01, 34, 40, 4runner, 5vz, 5vzfe, 96, 98, firing, fj, ignition, order, runner, sequence, t100, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Firing order YotaTwist General Electrical & Lighting Related Topics 1 05-18-2007 06:55 AM
Need to know firing order on the 3.0 suprathepeg 86-95 Trucks & 4Runners 7 10-09-2006 10:47 PM
'88 3vze firing order/cylinder layout mullet man 86-95 Trucks & 4Runners 2 06-14-2006 11:45 PM
Piston FIRING ORDER!!! pitm96 95.5-2004 Tacomas & 96-2002 4Runners 1 09-07-2005 10:18 AM
3.4L Firing Order/Cylinder Designations Rick F. 95.5-2004 Tacomas & 96-2002 4Runners 2 06-01-2005 04:59 AM
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
