Engine code ???
Old 03-10-2004, 06:22 PM
evanw66's Avatar
Engine code ???
I suspect that the 22R engine in my '84 has been swapped out at some point. I noticed that there is a number stamped on the block behind the alternator. Can I use this number to determine the year of the current engine?
The reason I think the engine has been swapped is that the oil pan has signs of being re-painted and the exhaust manifold is apparently an '85 and up style, because I had a friend give me an '84 manifold, but it looks very different than the manifold that I have.
Thanks...
Old 03-11-2004, 08:30 AM
85runner's Avatar
You could have a newer engine. 85 and up have single row timing chains - you could tell be removing the valve cover. I do not know how to check the # though.
Old 03-11-2004, 11:58 AM
evanw66's Avatar
It's definately a single row timing chain.
The number is 0942711. Can we tell the vintage from this number?
Old 03-11-2004, 05:25 PM
lunatic14r's Avatar
call L.C enginering they can help you
Old 03-13-2004, 10:55 AM
zendude's Avatar
why not take your number to a toyota dealer.
smthwsn357
12-04-2023 02:08 AM
mengquis
07-13-2015 10:39 AM
smiley52
07-11-2015 05:16 AM
Roger Borba II
07-09-2015 05:05 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Engine code ???
