hard start..HELP!
Old Mar 8, 2004 | 04:44 PM
skyepiper's Avatar
hard start..HELP!
Hi guys, I am a noob, and not experienced wrenching at all, just enjoy getting my hands dirty...
I just installed a reconditioned starter in my 99 4runner. Now it is hard to start, it just cranks away, and eventually will start, with a heavy fuel smell in the air....
I did not have this problem at all prior to installing the starter....
any ideas?
Is it possible I knocked something loose during the install?
thanks in advance
cheers
PJ
Peyton, CO
Old Mar 8, 2004 | 04:50 PM
MTL_4runner's Avatar
any ideas?
thanks in advance
cheers
PJ
Peyton, CO
Something is definately wrong there....
Double check what you touched and make sure you didn't knock anything loose.
A starter should not affect the car starting other than to turn over the motor.
Old Mar 8, 2004 | 05:18 PM
keisur's Avatar
you don't press the gas pedal while starting do you? that's not a good thing to do. that could be why you smell gas.
check to make sure all the plug boots are securely snapped onto the spark plugs.
Old Mar 9, 2004 | 02:28 PM
skyepiper's Avatar
okay, I went ahead and replaced my spark plugs, no problem, replaced the air filter, no problem. The 4runner starts now, but there is no power when I step on the gas...it is still rough starting....
Any ideas?
Old Mar 9, 2004 | 03:05 PM
My99's Avatar
Guess I'm unclear. There's no power when you step on the gas after the truck is running? This doesn't make any sense if all yo udid is replace the starter. If nothing else, pull the starter off and take it to a local autozone and have it tested. They cna make sure it's working properly on their diagnostic machine. Sounds like you could be causing a good deal of harm if your starter is bad. Otherwise, there's some strange coincidence happening. I'd rule out the starter first though.
Old Mar 11, 2004 | 04:12 PM
skyepiper's Avatar
Is it possible that this is an ECT problem? It is almost as if you were trying to start out in 3rd gear or something...
When I first started having problems with my starter, I would turn the key and just get click...then if I took the auto shifter out of gear into park, and then back into drive, it would start. Eventually that trick no longer worked, which is when I put the recon starter in.
Old Mar 13, 2004 | 11:15 AM
zendude's Avatar
sounds like the park/nuetral interlock is failing or maybe you have a loose wire or connection there. sounds as if your starting is working fine. keep eliminating the possible problems as you go. eventually you'll find it.
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
irv
Sep 29, 2015 06:20 PM
charlie_fong
Sep 27, 2015 10:06 PM
anndel
Sep 10, 2015 08:50 AM
