electric fan
Old 04-12-2004, 11:32 PM
nigeltufnel3's Avatar
Arrow electric fan
i've searched the topic and haven't been able to find much. I have a 94 22RE and just want to add some performance. what do you guys think about adding an electric fan? is it worth it? where should i look for one? thanks for all the help....
Old 04-13-2004, 04:27 AM
ElwayLite's Avatar
I had one on my v6 ranger just because it was such a dog. They really do help and you can tell it in the throttle response. I dont know about the yota's but the ford fan was heavy and hung right on the waterpump. I got an entire kit from Summit which explained what size fan you needed for what size motor and it was auto on and off. Spent about $150 for the whole kit.
Old 04-13-2004, 06:51 AM
Robinhood150's Avatar
Do a search for taurus fan.
Old 04-13-2004, 07:24 AM
Churnd's Avatar
Or read this: https://www.yotatech.com/~corey/tech...fan/churnd.htm
I would pick a taurus fan over that one though.
Old 04-13-2004, 10:15 AM
hey, thanks for all the info guys...what is the advantage of a taurus fan...when i looked for electric fans on ebay i found a bunch...is there something special about the taurus fan??? thanks again...
Old 04-13-2004, 11:21 AM
rimpainter.com's Avatar
The Taurus fan mod is cheaper and the results are the same as a more expensive dual fan set up - arguably better.
Don't expect your rig to be a screamer after a fan mod.
I would get Intake/Header/Exhaust first if I had the 22re.
Old 04-13-2004, 11:25 AM
Churnd's Avatar
Cheap, dual speeds, and more cooling than you'll ever need. Guys who do V8 swaps also use this fan, as the high speed does a good job of cooling those beasts.
You do not want to be stuck with a fan that'll let your engine overheat slowly sitting at a stop light.
Old 04-13-2004, 12:58 PM
thanks again....so when i go to the junkyard, what year taurus should i look for and what parts do i need????
Old 04-13-2004, 05:31 PM
notaco's Avatar
I would, wish I had, go with the taurus fan. I have a Hayden from "the zone". Let me say it sucks. It does alright in town but its not strong enough for wheeling purposes. I plan on switching to the taurus fan soon.
Old 04-13-2004, 11:11 PM
mp101v's Avatar
mid 80s to early 90s
Old 04-14-2004, 06:02 AM
Waterboy's Avatar
https://www.yotatech.com/forums/show...ght=Taurus+fan
kawazx636
10-06-2021 03:03 PM
Obmi
10-04-2015 11:30 AM
voiddweller
09-28-2015 11:21 PM
Matthew Perez
09-28-2015 05:43 PM
Project90
09-24-2015 11:40 PM
Quick Reply: electric fan
